It is currently Mon Sep 21, 2026 11:01 am
Post new topic Reply to topic  [ 44 posts ]  Go to page Previous  1, 2
Vehicle: suzuki sierra 91
Post Posted: Sun Apr 15, 2018 2:52 pm
Yeah
Got bored and after making recovery points this morning figured I’d give it another go
The pcv shouldn’t suck air in should it ?
Post Posted: Sun Apr 15, 2018 6:04 pm
Never really played with it myself. Quick google http://www.dummies.com/home-garden/car- ... pcv-valve/
Post Posted: Sun Apr 15, 2018 7:54 pm
yeah apparently it shouldn't suck at idle then sucks a little at mid then none at top
we have put it down to issues with vaccum because when you close the choke she will idle a lot longer so the extra pressure is pulling more fuel in giving me idle
Post Posted: Mon Apr 16, 2018 1:56 pm
generally ive found idle problems to be in 2 places (beyond these is not within the scope of me trying to explain it to you on an internet forum)
1. fuel cut solenoid under accel pump arm , thing with 2 wires going to it. its job is to cut fuel from the idle circuit to stop overunning engine when you switch the ignition off. generally they either work or dont work. when you put your finger on it and can feel and ever hear an audible "click" generally means its ok.
2. idle air bleed jet. in the last pic in this thread you can see a brass jet with two flats on the top . this is the jet that bleeds air with the fuel pulled from the primary slow jet to atomise it and produce a smooth idle. when you take it out there is a tiny tiny hole in the end that gets blocked and causes the car not to idle. normally when it gets semi blocked you can hear a "slurping" sound from the primary venturi. this is because rather than atomising the fuel it is causing droplets of fuel which will cause a poor or no idle situation. unscrew it you can look from the top end through it and should see the hole at the other end. clean it out by either blowing compressed air or ive used a very fine gauge single copper wire to poke through before.
Hope this helps
Post Posted: Mon Apr 16, 2018 4:36 pm
Well there’s good news and there bad news
Good news might not be the Carby
Bad news I’m sitting on the side of the road waiting for a tow so I can get home and find out
Post Posted: Mon Apr 16, 2018 5:07 pm
Oh oh.. what happened and what makes you think it’s not the carby now?
Post Posted: Mon Apr 16, 2018 5:56 pm
Might still be the carby but having issues with leads on top of that
One of the leads had come off and is not held on with duck tape
But on the good news the new carbys is here
Post Posted: Mon Apr 16, 2018 6:44 pm
Brilliant!! See what happens once it’s in :)
Vehicle: 91 Tin Top
Post Posted: Mon Apr 16, 2018 7:03 pm
Should be able to get a full lead kit with new rotor and cap off ebay for about $60. One of the Sydney sellers will get it to you in a couple of days.
New carby and a tune up kit should help get it humming along again nicely. ;)
Post Posted: Mon Apr 16, 2018 9:00 pm
yeah lead kit on the way
another plus is I'm borrowing the boss's SS with all the fun stuff I forgot what it was like to have power to go
Post Posted: Sun Apr 22, 2018 1:07 pm
So new leads didn’t fix the problem well there might have put I broke the dizzy cap so it got replaced as well
And I have finished the install of the carby pretty much
Enough that she will run and idle I just need a bolt to bolt the hat back on and a little tuning and it’s good to go
Post Posted: Sun Apr 22, 2018 5:42 pm
Good result!! Hopefully it all clears up with the new carby on
Post Posted: Mon Apr 23, 2018 12:09 pm
Got to take it for a bit of a test run to go get my lunch
Seems ok most the time expect when you plant it it seems to hesitat then jump a bit before it takes offs
Been told to swap the secondary out of the stock carby into the 4K and should help it
Post Posted: Mon Apr 23, 2018 3:07 pm
Sounds reasonable!! The 4K is set up for a different motor so that might work
Users browsing this forum: No registered users and 40 guests
