It is currently Mon Sep 21, 2026 3:08 pm
Vehicle: LJ80
Post Posted: Sun Jun 17, 2018 10:07 pm
I know it's a well know fact that these nuts are the hardest to remove, but really this is beyond belief. Heated up till its glowing, not even sure if its left to right hand thread (respect to Mick) HELP!!!!!
Vehicle: lj80
Post Posted: Sun Jun 17, 2018 10:35 pm
normal thread. need a 800nm+ rattle gun.
worst case -> grind a groove in it and cold chisel it
Vehicle: LJ80
Post Posted: Mon Jun 18, 2018 1:15 pm
800nm+ WOW that's a lot of torque, I'll try the groove and chisel. Thanks Aircobra101.
Post Posted: Mon Jun 18, 2018 9:41 pm
800? no way. Maybe for a fully sealed type bearing. 400nm from memory for a Prado. 800nm on 2 taper bearings would crush the cages and jam the hub up if the nut threads didn't let go first.
Wheel bearing nuts will be normal right hand thread, Left loosy, righty tighty.
Vehicle: lj80
Post Posted: Mon Jun 18, 2018 9:46 pm
something like this
https://www.bunnings.com.au/kincrome-ai ... h_p6270670
https://www.bunnings.com.au/kincrome-ai ... h_p6270672
https://www.bunnings.com.au/ryobi-airwa ... h_p6210629
570nm is not bad for the price, but no guarantees
if your vehicle is immobile, go to the local tyre shop, leave them a $300 deposit and borrow the gun
heating it up is a bit of a con since the nut expands in ALL direction, including onto the shaft
Vehicle: LJ80
Post Posted: Tue Jun 19, 2018 7:32 pm
Thanks for all your help and direction. I will let you know how it goes.
Post Posted: Wed Jun 20, 2018 6:00 am
They're normal thread.
Get a big cheater bar, put the handle on the ground and drive the car? Or have an assistant stand on the brake whilst you reef on it. Mine actually came off relatively easily.
The best solution is pull the king pins out, remove the whole assembly, apply it to a bin and fit Sierra disc brake swivel hubs! :D
Vehicle: LJ80
Post Posted: Wed Jun 20, 2018 7:39 pm
Car stripped, no brakes.
That's what I'm doing :)
Vehicle: lj80
Post Posted: Sat Jun 23, 2018 8:47 pm
800nm is to undo the nut. who's talking about crushing bearings?
Users browsing this forum: No registered users and 50 guests
