It is currently Mon Sep 21, 2026 2:28 pm
Vehicle: lj80
Post Posted: Thu Jul 19, 2018 8:10 pm
my one is stuck solid. i think someone stuck the shaft into so hard, it jammed the cage
i've tried jamming it with a screwdriver, but i can;t get an edge on it and i dont want to scratch the surface
the issues is that the standard chinese/repco 3 jaw pullers have a 13mm min diameter and the hole is 10mm exactly
any ideas?
Vehicle: lj80
Post Posted: Thu Jul 19, 2018 8:13 pm
even this one is 11mm
Vehicle: lj80
Post Posted: Thu Jul 19, 2018 8:22 pm
i mean this one
https://www.ebay.com.au/itm/5-pc-Inner- ... =R40&rt=nc
Post Posted: Thu Jul 19, 2018 9:45 pm
I’ve seen someone remove a stuck fast one using hydraulic pressure. They filled the hole with as much grease as possible, found a round rod to fit as snug as possible (but not tight) in the hole and tapped the rod firmly with a hammer.
The resulting increase of pressure behind the bearing pushed the bearing outwards
Post Posted: Thu Jul 19, 2018 10:04 pm
Bread/grease/hand cleaner/ anything thick and a pin punch the right diameter.
Post Posted: Fri Jul 20, 2018 10:44 pm
Im a mechanic and an engineer and steve is sort of on the money but not quite there. Grease etc is still too viscous and can never really reach a "solid" state.
So i use...................
Paper.
Soak paper in water keep punching it in with drift the size of bearing id.
Water pushes out paper becomes solid and pushes bearing out.
Post Posted: Sat Jul 21, 2018 7:34 am
Why does it need to reach a "solid" state - does the hydraulic fluid in a 12 ton press ever reach a solid state?
Vehicle: Coily.
Post Posted: Sat Jul 21, 2018 9:36 am
I haven't done one for years but the Ford ones in the 4 Cylinder Motors, (Escort,Cortina etc) ,often use to seize in and we used those masonry bolts that tighten and expand,small dent type slide hammer behind a washer and end nut and they use to pop out easily.
Regards All from far Northern NSW.
Post Posted: Sat Jul 21, 2018 11:02 am
https://youtu.be/2TBZH5R4Cno
Bread also works but i'd assume bread will be in your tummy and grease will be lying around the workshop.
Vehicle: lj80
Post Posted: Sat Jul 21, 2018 7:39 pm
harry's idea looks like the winner to me. why didn't i think if that?
Post Posted: Sat Jul 21, 2018 7:47 pm
Seems harder than a bit of grease to me.
Post Posted: Sat Jul 21, 2018 9:15 pm
All good ideas fellas!! Will tuck those away in the memory banks for a frustrating day
Vehicle: 92 WT Sierra
Post Posted: Sun Jul 22, 2018 5:14 pm
In my LJ the needle roller just pulled to pieces with the puller after the grease trick and others didn't work. Just got a tiny 2mm carbide burr ($30 at bunnings) and cut a slot in the outer race until it came loose.
Worked a treat but I'd only keep it as a backup plan
Users browsing this forum: No registered users and 40 guests
