i've been trying to work out why none of the carb kits fit my carb the signs were there - slightly wrong shape of the gasket, different float then i looked closely and it says aisin, which was standard on SJ410 for a F10A so - that looks like the legit carb is a solex (copy?) have i got the story right and can i leave the carb?
but will it work? do you know if the mounting studs are different? rebuild kit for the aisan is $80 and I can get a brand new f8a carb from china for $100aus !! at least i can keep my manifold
Yes the F10a carb will work. They're easy to change jets on if you need too. They're both 32mm diameter throttles.
The mounting studs are much wider on the F10a carb. The manifolds are different but only in the mounting of the carb.
F8a carbs after 1981 (on Carry vans) are the same as F10a carbs with the wider spacing. So if you're buying new then take caution. I don't think there's any new LJ80 style F8a carbs for sale.
Users browsing this forum: No registered users and 76 guests
