It is currently Wed Oct 07, 2026 7:17 pm
Vehicle: MY2019 Jimny
Post Posted: Mon Sep 28, 2009 10:56 pm
Halp!
I cannot get the speedo gear unit out of the transfer case, I think the gear is a bit munted as the main cluster turns, but the gear shaft doesn't....
I removed the retaining screw, but no matter how tight I grip the sleeve, I cannot get it to budge. I have already had one case destroyed, I don't need another fucked.
I have access to bugger all equipment, but may have some gear at work that I can use...
Post Posted: Mon Sep 28, 2009 11:25 pm
The little tag the retainer goes through, give it a lil TAP with a hammer side way`s, you want to turn it not snap it. That should loosen the o`ring seal up. If you can get it to turn, get the tag so you can get a screw driver under it 7 again TAP upwards.
Hope that help`s
Post Posted: Mon Sep 28, 2009 11:26 pm
yep that should work steking
 Profile YIM
Post Posted: Mon Sep 28, 2009 11:31 pm
Just had a thort tho, is there a tag? or dose the bolt go through the drive?
I spend to much time on new shit box`s.
Post Posted: Mon Sep 28, 2009 11:50 pm
the retaining bolt goes through the sleeve and locks into a recess on the cable. Pull the bolt all the way out and try to twist the sleeve. if it twists then it should come out.
i just rebuilt another t/case and had trouble getting the speedo drive out as it was stuck in wih silicone. gave it a twist and pulled at the same time and it came out that fast i smacked myself in the mouth.
Post Posted: Tue Sep 29, 2009 1:49 am
:lol:
Have done things similar once or twice. Luckily no one else is usually around!
Post Posted: Tue Sep 29, 2009 2:08 am
Yeah this one is stuck fast - any ideas anyone?
Post Posted: Tue Sep 29, 2009 2:11 am
Vice grip`s & turn the Tap into a Hit...
Post Posted: Tue Sep 29, 2009 3:07 am
Is that up on Youtube? I'd like to see that.
Post Posted: Tue Sep 29, 2009 3:14 am
vice grips worked on mine. dont try and pull it just twist it first
Vehicle: '92 Sierra
Post Posted: Tue Sep 29, 2009 11:35 am
This might be completely retarded as its been years since I rebuilt my case but could you get compressed air in their to help push while you pull?
Post Posted: Tue Sep 29, 2009 11:46 am
Prob not, can't get to the other side...
Would some heat help, or is that a no no with alloy?
Post Posted: Tue Sep 29, 2009 1:34 pm
Well I got it out finally- turned it using vice grips, with a shifter on those. heaps of fox piss, then tapped the vice grips with a hammer, and out she popped.
No visible damage either - weird!
Post Posted: Tue Sep 29, 2009 3:31 pm
Hi mate good to see you got it out in the end.
I put rockhoppers in mine last weekend. Mine was as hard to get out. I ended up using a bench press to press the outputshaft out. I did thid very very slowly. I could see the speedo was spinning. I did the save to put the shaft back in. It was very risky but it worked. I have driven it for 4 days now ans it is working soo this mite be a last resort for anyone next time.
Just go slow and be carefull.
Post Posted: Tue Sep 29, 2009 11:16 pm
Thankfully nobody else was there to see it. but fuck it hurt.
Users browsing this forum: No registered users and 221 guests
