Suzuki X90 Targa Roof drainage conundrum. Cleaning the rear drain holes for the X90 Targa top, the water disappears, there are gurgling noises, and yet there is no sign of water exiting from below. I am hesitant to pull the inside lining out to see how it works.....Does any one have a drainage diagram or parts diagram, or knowledge of the drainage system for the X90 Targa roof? Any insight appreciated. Col
The workshop manual offered nothing useful and the parts diagram only shows the drain hoses, these are 1.5m long and maybe exit behind the sills. Hopefully not into them
Thanks Darrell and Joe. Yes I'd better check the sill holes for blockages. Funny thing is, when I put air from a tyre pump down the drainage hole from above, there is a gurgling sound from within at about arm rest height. I guess I'll end up needing to pull the inside panelling apart to solve this mystery.
Users browsing this forum: No registered users and 77 guests
