It is currently Mon Sep 21, 2026 1:42 am
Vehicle: 1992 Sierra sj70 Tin Top
Post Posted: Thu Mar 07, 2019 4:20 pm
Hey guys
Sorrry for so many somewhat silly questions,
What's a serria 1.3 clutch suppose to feel like, mine feels like it's got a lot of travel and then it bites at the end of its travel if that makes sense, can't feel it slipping or anything. Is that just normal for a serria
I’m not really sure why Penrite is held in such regard other than parochialism. Boomers seem to love it though.
Post Posted: Thu Mar 07, 2019 5:15 pm
It will be a cable set-up so you can adjust it to make it grab lower to the floor.
Post Posted: Thu Mar 07, 2019 5:29 pm
my last cars have been xr5 turbo evo and turbo foz, this cable everything old school stuff is new to me :oops: :oops: i will download the FSM and start having a good look through it
Vehicle: Carless
Post Posted: Thu Mar 07, 2019 7:19 pm
Welcome to owning some of the best car types out there, old school none of the fancy eletric rubbish in new cars just old fashed stuff where you can turn into a submarine if your engine is sealed tight and you have a decent snorkal set up going (could do this and it would look neat http://www.auszookers.com/forum/viewtop ... 27&p=84637 ).
Post Posted: Fri Mar 08, 2019 9:29 am
i will mess with the clutch cable some more, someone was saying that if the old owner installed a HD clutch then that could also explain why it bites high. might end up swapping it back to oem clutch at some stage if thats the case.
Post Posted: Fri Mar 08, 2019 10:05 pm
The lever that the cable acts on, is held to the clutch fork shaft with a pinch bolt on a spline - this can be removed & moved around a spline or 2 to adjust travel as well.
Rgs, Michael
Users browsing this forum: Google [Bot] and 68 guests
