It is currently Sun Oct 11, 2026 4:30 am
Post Posted: Mon Sep 28, 2009 12:00 am
hey guys finally got my car running today :D. onbe problem is that put the starter motor in and when u turn it over it makes like a grinding noise i have put all the plates that wer eon last engine in im sure and its the same starter motor any one have any idea why this would be happening??
Post Posted: Mon Sep 28, 2009 12:20 am
does it turn over, start then make a grinding noise for 2 to 3 seconds then stop?? if so, you will just need to pull it out, take it apart, note the way the fork that throws the bearing in and out came out like, then clean and grease it all up again. put it back together and bam all fixed.
hope that helps.
Post Posted: Mon Sep 28, 2009 12:58 am
No when you go to start makes a loud squelling noise amd sometimes it tries to turn over and again makes a really loud clunking noise. When push start its fine something to do wqith starter.
Post Posted: Mon Sep 28, 2009 2:09 am
did you use a sierra starter or a vitara reduction starter ? because the sierra starter foul's on the 1600 block and requires grinding of either the block or the starter motor, if this isnt done then it causes misalignment of the starter motor and incorrect meshing of the starter to the ring gear.
So your choices are either grind back your starter where it fouls on the block, or
Find a 1600 reduction starter as they bolt straight in and clear everything and have more torque than the 1300 sierra starter, thus making them a better starter and longer lasting
Post Posted: Mon Sep 28, 2009 3:12 pm
hey im not sure as its a new engine that could quiet possibly be the problem i will check the old block and see if he has grinded the block down as i have only ownd the car for like a month and it has always had the swap thanks for your help will let you know how i go. Do you know where i could get a new starter from either secondhand or new. Have rang a few places and no one seems to have one.
Post Posted: Mon Sep 28, 2009 11:02 pm
you rang me this afternoon didnt you...
Post Posted: Tue Sep 29, 2009 12:17 am
i spoke to 2 places today and no said that they had one, someone said they think they have one and will ring tomorrow if they do hopefully thats you and can get one.
Post Posted: Tue Sep 29, 2009 12:58 am
X2
Vehicle: SJ80
Post Posted: Tue Sep 29, 2009 1:17 pm
Sorry to hijack but does anyone have a part number for the 1600 reduction starter? All the vit ones i've found down here have the same starter as my sierra. I'm running a modified colt (not 100% sure) starter but i'd prefer the 1600 option. I didn't fancy taking to my block with the grinder to fit the sierra one! Cheers!
Bronson
Vehicle: 85 SJ413
Post Posted: Tue Sep 29, 2009 7:08 pm
M1T72481 31100-60A20
Ben
WWW.ZUKPARTS.COM - Quality Suzuki Off-road Parts
Post Posted: Tue Sep 29, 2009 10:22 pm
its from the efi 1600 vitara
Post Posted: Tue Sep 29, 2009 11:06 pm
i dont have one but i am waiting on a shipment , they shouldnt be too far away , possibly in the next couple of days.
Vehicle: SJ80
Post Posted: Wed Sep 30, 2009 1:38 am
Ben
Thanks muchly! My vit 16v vit motor came with the chunkier sierra style starter. And when I tried to buy a new starter from the auto elecs they couldn't get the slimmer style model and told me they had probably been superseded?
Post Posted: Wed Sep 30, 2009 2:13 am
hey i can get the reduction starters.... brand new
Post Posted: Wed Sep 30, 2009 2:19 am
I was waiting for you to notice this. :wink:
Can you get me a price on a Gv SQ625 please?
Post Posted: Wed Sep 30, 2009 2:30 am
how much $$$
cheers
Vehicle: SJ80
Post Posted: Wed Sep 30, 2009 2:41 am
ajsr wrote:
how much $$$
cheers
X2 :D
Users browsing this forum: Google [Bot] and 260 guests
