It is currently Sun Aug 30, 2026 7:24 pm
Vehicle: 87 Samurai
Post Posted: Wed May 08, 2019 2:30 am
For you spua fellas......
What do you have, or have made, to protect the leaf spring U bolts and nuts from damage....scraping over rocks and such?
A skid plate?
Got pics ??
Vehicle: 95 sj70 and 78 lj81
Post Posted: Wed May 08, 2019 6:41 am
Check through my build page, l made some for th front that work really well
Vehicle: Suzuki SJ413
Post Posted: Wed May 08, 2019 4:38 pm
I have made raised u bolt plates before, they worked well.
Vehicle: 86 SJ413 31's 1.6
Post Posted: Thu May 09, 2019 3:18 am
I have some of these calmini ones that i was going to use. But the shock mounts are pushed back to suit their 5 inch lift kit. But would work if your pushing the front diff forward. But I'm not doing ether so im selling them. But im in NZImage
Sent from my SM-T350 using Tapatalk
Post Posted: Thu May 09, 2019 5:38 am
I had the calmini ones and they work well. It’s the plate that pushes the diff forward so all that is needed to move the diff is those plates
Post Posted: Thu May 09, 2019 8:45 am
If you’re theoretically worried about it weld plates over the bottom of the stock u bolt plates and ensure the u bolts are trimmed short.
If you’re finding the ubolt plates a significant issue on the trail (and this is unlikely given your stated use) follow redzuki’s advice, or weld larger spring saddens to the axle and use cap head bolts up from underneath to make a flat skid.
The easiest way to prevent this being a problem is to run more rim backspacing. The cars with 2.5” BS rims are the cars that get hung up on the u bolt plates.
Vehicle: 87 Samurai
Post Posted: Mon May 13, 2019 11:48 pm
Thanks for your suggestions.
Gives me some ideas.
Never thot about the wheel offset.......makes sense.
Users browsing this forum: Andygoodbloke and 82 guests
