It is currently Wed Sep 30, 2026 10:22 am
Vehicle: 2006 suzuki jimny
Post Posted: Mon Jun 17, 2019 7:36 pm
I have recently just had me gearbox fully rebuilt and a new clutch fitted in my 06 jimny manual
The issue im having is selecting 1st gear i had issues shifting to first time before the rebuild and the clutch. and after the rebuild and new clutch in im still having issues.it sometimes shifts ok but other times it just wont go into first and need either abit of force of i have to put it into neutral and then shift to first
Just woundering is it something i just have to give it abit of time for all the new parts to wear in??
Or is it just a common jimny thing?
Vehicle: 2016 Grand Vitara 3 door
Post Posted: Mon Jun 17, 2019 8:13 pm
When cold or first thing in the morning then fine
Post Posted: Mon Jun 17, 2019 8:17 pm
First thing in the morning its fine its when it starts to warm up is when i have the shifting issue into first
Post Posted: Mon Jun 17, 2019 8:19 pm
Not sure if the clutch may just need adjusting as everything is brand new
Vehicle: 1992 Sierra sj70 Tin Top
Post Posted: Tue Jun 18, 2019 10:39 am
what oil did you fill it with ? any of the linkage loose ?
I’m not really sure why Penrite is held in such regard other than parochialism. Boomers seem to love it though.
Post Posted: Sat Jul 06, 2019 8:27 pm
So it only wants to go into first if im at a complete stop which can be very annoying when just rolling at walking pace or slowing right down to traffic lights i just gave to stay in second unless i completly stop the car is this just normal for a jimny?
Post Posted: Sat Jul 06, 2019 8:59 pm
Not normal. Clutch isn’t fully disengaging.
Post Posted: Sat Jul 06, 2019 11:15 pm
When that happened to me the clutch cable was on its way out and snapped mid-gear change down to first. Drove it home clutchless (rev matching, stalling at lights) and replaced the cable that day.. all good again since. Mine broke at the bearing that goes onto the clutch pedal, so that joint was flexing, but working even though it was broken until it fully let go.
Post Posted: Sat Jul 06, 2019 11:18 pm
Wouldn’t a 2006 Jimny have a hydraulic clutch? Sorry, bit ignorant about M drivelines.
Post Posted: Sun Jul 07, 2019 3:09 am
The 2004 M jimny I service has cable still steve. Id assume 06 still would?
Post Posted: Sun Jul 07, 2019 8:32 am
Fair call.
Misadjusted or stretched cable then for my money.
Post Posted: Sun Jul 07, 2019 6:04 pm
I thought it could of been the clutch, when my mechanic done the rebuild of the gearbox and installed the new clutch he did mention that he may have to adjust the clutch pedal later down the track, he said that he couldn't adjust it to much at the time when he installed the new clutch as the clutch plate is alot thicker than my old one (as my old one was very warn down), could that be the reason?? Once he adjusts it abit it should be better?? It was always a pain to get into first before the rebuild but i never had to come to a complete stop to put it into 1st.
Post Posted: Sun Jul 07, 2019 8:47 pm
You can adjust it yourself... FSM says something like 1" of pedal free travel and job done, but if you have that then maybe the cable has a kink or like I said before is on it's way out. Cables are about $50 genuine, and take about 15-20mins to fit and adjust if that's the cause.
Post Posted: Sun Jul 07, 2019 9:00 pm
Yep. Pedal free play is the only variable.
Users browsing this forum: Google [Bot] and 124 guests
