It is currently Sun Nov 15, 2026 12:59 am
Vehicle: suzuki ute
Post Posted: Sat Aug 10, 2019 9:42 am
I recently bought an GTI engine /5 speed trans, loom etc to do a conversion on my Sierra, what clutch is everyone using as I want to replace it before fitting, is it a standard Sierra 5 speed clutch or a combination of Sierra and GTI,Also what airbox set up, it has a pod filter but I'm not keen on using that, it also needs a new dist cap, I read somewhere that a Barina one is used, does anyone have a part no, the other problem is a broken vacuum valve on the inlet manifold (see pic ) any idea what it is called so I can organise another, first pic is the zook it will be getting fitted to.
Post Posted: Sat Aug 10, 2019 5:28 pm
zook ute wrote:
The other problem is a broken vacuum valve on the inlet manifold (see pic ) any idea what it is called so I can organise another, ........
Vacuum Switching Valve Assembly (VSV): 18117-64B50
There should be two black rubber vacuum lines going to this valve, do you have the other one?
Dizzy cap and rotor usually used is Mazda 323: viewtopic.php?f=5&t=55129
Vehicle: suzuki ute
Post Posted: Sat Aug 10, 2019 10:45 pm
Thanks for the help 303, yes the other line is there, thanks for the link on the cap/rotor.
Post Posted: Sun Aug 11, 2019 12:56 am
Well purchased - a lot of work has gone into that car.
Very good start on getting a beasty back on the road.
Good luck with it.
Rgs, Michael
Vehicle: suzuki ute
Post Posted: Sun Aug 11, 2019 10:24 am
Thanks ZUZUKI, the car is a bit different than it looks in the pic (the pic is from 10 years ago) can't wait to get it done but it's going to take awhile.
Vehicle: Twin cam Sierra
Post Posted: Mon Aug 12, 2019 10:00 am
viewtopic.php?f=17&t=36242&hilit=gti+conversion
I did my full conversion pretty much from this link.
Twin Cam Sierra 4" lift 31's
Vehicle: suzuki ute
Post Posted: Mon Aug 12, 2019 2:16 pm
Thanks for the link, lots of good info in there.
Users browsing this forum: No registered users and 81 guests
