[ 4 posts ] |
Print view
Previous topic | Next topic
| Author |
Message |
Andy1985
Joined: Sun Nov 10, 2019 8:45 pm Posts: 2 Location: Adelaide
Vehicle: Suzuki sj40
 Posted: Sat Nov 16, 2019 1:10 pm |
Hi guys,
new member to the community but have been reading a lot of useful information in the last couple of weeks. My partner just fullfilled her dream and got a Suzuki sierra 84 hard top. Cars is in fairy good condition for its age. The only immidate thing that we need to address is the steering. Apparently the steering housing is leaking and it feels like the car is aiming for the nearest tree whilst driving. Instead of repairing the steering, we are thinking about upgrading to power steering straight away. From what I have read here is, we have to options: Get a vitara PS assembly and the bent kit or a jimny PS assembly, which is a straight bolt on, but we would loose some steering as the pitman arm is shorter. Question is, is all I need the PS steering assembly (pump, reservoir, hoses, steering housing) or anything else? The car has a g16b engine conversion.
Hope you guys can help me, as I am just learning all about the car and what needs to be done and how to work around the car.
Regards Andy
ZUZUKI
Joined: Thu Sep 02, 2010 5:50 am Posts: 427 Location: Melbourne
 Posted: Mon Nov 18, 2019 9:08 pm |
Hi andy, Good that you have a G16b already, as that should be running multi-rib belts already, which is what ever pump you run will have. I haven't done this to a 1.0litre chassis, but you might find clearance issues with the radiator supports with either or both the box and/or pump. The hoses / steel pipes will need a fair bit of 'manipulation' to fit - the Jimny ones are much closer to being right than Vitara ones, although a industrial hose repairer like Pirtek or Enzed can make custom hoses up. There are variations on pump mounting brackets, as the G13bb / G16b has been fitted to a few different models - some are semi incorporated with an A/C compressor bracket, which is not ideal - unless you want to run A/C as well!. Rgs, Michael
Andy1985
 Posted: Thu Nov 21, 2019 2:50 pm |
Thanks mate, yeah they're isn't much space at all near the radiator as a new bigger radiator has been installed. Guess I need to some more research and compare pics what could fit.
tanked82
Vehicle: 1989 Sierra soft top
 Posted: Tue Dec 31, 2019 7:08 pm |
I have a 89 soft top, just done a electric power steering conversion, using astra power streer pump and jimny box was some work but I am loving it. Let me know I can go into more detail if you want
[ 4 posts ] |
Users browsing this forum: No registered users and 43 guests
