It is currently Mon Sep 21, 2026 3:06 am
Vehicle: 1992 Sierra sj70 Tin Top
Post Posted: Wed Nov 27, 2019 8:43 am
Hi guys
when doing a baleno swap into a seirra i have opted to use my existing sj70 tank paired with a PIERBURG 7.21287.53.0 as my tanks only 5 months old and i dont see myself doing any extreme off road with mega angles. plus i'm a lazy C#$# and its one less thing to have to pull out lol
my question is. my mechanic friend was saying i should hook up a LPG Safety switch between the fuel relay and the pump for if the car stalls ?. do you think this is a must ? or can i get away with just running some nice 2 core down to the pump with nothing in between.
I’m not really sure why Penrite is held in such regard other than parochialism. Boomers seem to love it though.
Post Posted: Wed Nov 27, 2019 10:30 am
IF you're using a standard Baleno ECU to run the engine and controlling the fuel pump from that, it's not necessary - the ECU will shut the pump off if the engine stops.
Post Posted: Wed Nov 27, 2019 1:50 pm
awesome thank you sir, i will just run the 2 core down to the pump, thank you.
Fat pink wire out the baleno harness handles the power to the fuel pump via the relay in the fuse box.
Initially when ignition is switched to on position you should hear fuel pump prime for 4 secs then shutoff until car is started.
Post Posted: Wed Nov 27, 2019 3:02 pm
yeah i had some guy cut down my engine loom into a nice small one with just everything it needs to run on it with all the labels and inline fuses so should be all good.
one more silly question for you mr rocky. the instructions for this pump came in German hahah can i guess that side of the pump with the neg and pos connections is the outlet to the fuel rail up to the filter and the motor and the larger side of the pump is the inlet from the tank ?
Post Posted: Wed Nov 27, 2019 9:42 pm
Good question, buggered if i can remember haha
I thought there was an arrow on the pump perhaps ?
Might be time for google translate.
Remember to make sure your tank is clean or the internal mesh filter on the pump will clog
Post Posted: Wed Nov 27, 2019 11:55 pm
Out of curiosity, is the mesh filter accessible to clean it if required?
Post Posted: Thu Nov 28, 2019 7:33 am
Yeah you can pop it out easily but efi pumps normally dont like running dry for too long :deadhorse:
Post Posted: Thu Nov 28, 2019 10:41 am
from what i can see on this pump the large end has a filter inside it and the small end with the neg and pos terminals is a smaller barb has no filter visible so this to be would translate to large barb to tank small barb next to terminals is up to engine
on this one the filter does look like its pops out to be flushed or replaced most defs
Post Posted: Thu Nov 28, 2019 6:10 pm
I normally also use a diahatsu feroza fuel pump bracket to mount the pump to the chassis. It rubber mounts the pump and is the perfect size
Users browsing this forum: No registered users and 51 guests
