It is currently Mon Sep 21, 2026 12:06 am
Vehicle: buying
Post Posted: Mon Feb 03, 2020 2:50 pm
Hi,
Would a long range coily fuel tank (brown Davis) fit in a 1987 sierra to be used as the efi fuel tank for a g16b conversion?
Figured since I have to change the tank, might as well go a long range tank.
Cheers,
Tim
Post Posted: Mon Feb 03, 2020 3:09 pm
A coily tank will bolt into a leafy sierra so i can't see why a longrange coily tank wouldn't fit a leafy
Post Posted: Mon Feb 03, 2020 3:42 pm
It’s unlikely the long range tank has provision for the in tank pump and swirl pot- they were redundant in the Australian market, it’s just good fortune the SJ80 tank was set up for them. You’re likely to have to use an external lift pump/swirl pot/hp pump arrangement or mod the tank for a swimmer pump because the long range tank will just have a vent, pickup and return.
Tank should fit- I’d be surprised if Brown Davis changed the design between models, but watch for clearance around the rear shackles- they may have added capacity over the lead tank by using space the shackles need on a leaf car.
Vehicle: buying
Post Posted: Mon Feb 03, 2020 4:14 pm
Makes sense, I might just email them and see what the difference is between the coily long range and leaf one. I will post back when I get an answer
Post Posted: Mon Feb 03, 2020 4:16 pm
Actually I vaguely remember reading something about there being a difference on longrange tanks due to the shackles, think i may have read it in a old GRP catalogue
Vehicle: buying
Post Posted: Mon Feb 03, 2020 5:07 pm
Well I have emailed them now regards the differences in the tanks. Wonder if they could custom make one that has the leaf long range with the coily input so I can put a vitara EFI pump in.
On another note, in doing this conversion will the g16b rev the same? Because I have reduction gears on 31s and a t the moment sit at 3850 revs at 100. Will the G16b do the same and should I remove my reduction gears?
Post Posted: Mon Feb 03, 2020 5:27 pm
Engine will rev the same- only gearing or tyres will change rpm at a certain speed. The G16b will probably pull 100 with no reduction gears and 31’s but it will suck off road. 3850 is high though- you should be revving 3550 or so. You’re aware the reduction gears don’t correct the speedo yeah?
Post Posted: Mon Feb 03, 2020 5:38 pm
When I was looking into it one of the long range tank manufacturers offered the option of provision for vitara in tank pump, I can't remember which though.
4wdsystems was by a fair whack the cheapest, that was a year or 2 ago though.
Vehicle: buying
Post Posted: Tue Feb 04, 2020 7:47 am
Yeah I'm using gps speed cause my Speedo stopped working a long time ago. I don't know what type of reduction gears it has as it had them when I bought the car.
And good to know, I will have a suss of 4wd systems
Post Posted: Tue Feb 04, 2020 8:44 am
Still seems too high. Even if your 31’s are worn and short (29”- an extreme case) I still get about 3700 rpm max with 6.5 transfer gears. I’d be getting under the car and counting turns to work out what your transfer and diffs are.
Users browsing this forum: No registered users and 72 guests
