It is currently Sun Sep 20, 2026 10:13 pm
Vehicle: Holden Drover, Suzuki LJ81
Post Posted: Mon Aug 10, 2020 10:30 am
I have recently fixed the brake lights on my Suzuki Sierra and one side is working fine getting 12 volts but the other side is only getting 0.5 volts. what is wrong with this and how can I fix it.
Thanks
Gus
Done myself a mischief.
Post Posted: Mon Aug 10, 2020 8:03 pm
What is your experience with electrical troubleshooting & diagnosis? Where and how are you measuring that voltage? Both brake lights are supplied by the same feed so for one to get 12V and the other less than 12V can only be a bad connection or a broken wire. You'll need to check both the supply wire & the ground wire.
Post Posted: Tue Aug 11, 2020 8:16 am
Iv'e have a fair bit of experience with Landcruiser electrical problems. I have been measuring from the inside of the light housing using a voltmeter and grounding it to the chassis.
Post Posted: Tue Aug 11, 2020 8:21 am
Chassis is basically not grounded on a Sierra. There is one tiny wire that runs from the rear cluster on the passenger side from memory to the chassis, that's it.
Post Posted: Wed Aug 12, 2020 1:54 pm
Ok thanks i'll try that out
Post Posted: Wed Aug 12, 2020 2:37 pm
Take your ground measurement from the globe socket, not the body (or chassis) because it's not out of the question the problem is a poor ground on loom. Measuring between the +ve and the body will only prove the light has power, not whether there's a complete circuit.
Post Posted: Mon Aug 17, 2020 1:57 pm
thanks for the tip
Users browsing this forum: Google [Bot] and 60 guests
