[ 17 posts ] |
Print view
Previous topic | Next topic
| Author |
Message |
MUDFROG
Vehicle: Suzuki sierra SJ413
 Posted: Sun Oct 04, 2020 9:54 pm |
Hey all, bout to do some stuff to me zook, kinda new to all of this. Will be getting some 31" muddies on a 15x7 rim, and was told i would want to change the transfer case gears first then get chromo axels. was thinking of 6:5:1? Ive already got a 2"inch body lift in and will be getting a rear air locker in future. Is there anything else involved with changing the axels and gearing? other parts i need to get etc? Will be driving on road still to and from work, but wanna do it up for 4wding. Thanks in advance zook is a 1997 sj413 coily.
Gwagensteve
Joined: Thu Feb 26, 2009 10:30 pm Posts: 13011 Location: Melbourne
 Posted: Mon Oct 05, 2020 7:33 am |
I’ll reply in more detail tonight when I’m in front of a computer, but as you have a coil sierra things are a bit different for you.
You’ll need a complete leaf spring transfer case, jackshaft and front driveshaft in order to swap to lower transfer gears.
Cromo front axles aren’t easy to come by for an SJ80, and I’m not sure what side gears you’d need to fit the smaller SJ80 front diff. (1.0 litre rear?)
I don’t believe there is justification for cromo front axles of the front isn’t locked.
To be honest, a 31 is a big and heavy tyre to use on a daily. It’s the equivalent of daily driving a patrol on 37’s. Braking, in particular suffers significantly. 6.5’s will feels very low off road, especially with the front unlocked which will mean you’ll need to bump obstacles which will require some wheelspeed.
alien
Joined: Wed Mar 24, 2010 10:30 pm Posts: 16343 Location: Perth
 Posted: Mon Oct 05, 2020 7:44 am |
I reckon what you'll likely arrive at once you realise how much work it is to modify a coily reliably, is to buy an older leafy model or a newer jimny model... The aftermarket support for both far exceeds the coily models.
31" tyres & 5.14 tcase brings it pretty close to stock (I know, cos that's what I run) To fit 31's with just a 2" body lift you 100% need to cut the guards (search it on here, there's lots of guides with photos) Worth noting than even with 31s the stock rear axles WILL twist once you add a locker. It's only a matter of time. Also worth noting that over a 225/70r15 or thereabouts is not road legal (you mentioned daily driving it)
Gwagensteve
 Posted: Mon Oct 05, 2020 7:49 am |
alien wrote: To fit 31's with just a 2" body lift you 100% need to cut the guards (search it on here, there's lots of guides with photos) Worth noting than even with 31s the stock rear axles WILL twist once you add a locker. It's only a matter of time. I disagree with this Alien. The coil sierra I worked on extensively ran 31 10.5 centipedes with no guard cutting with a 2” body lift and a very small front bumpstop spacer (~10mm) We have not found rear axle longevity a problem at all with 31” tyres and a locker.
alien
 Posted: Mon Oct 05, 2020 8:04 am |
Maybe I drive differently... I went through two lots of rear axles in mine before upgrading them =)
Gwagensteve
 Posted: Mon Oct 05, 2020 8:20 am |
Id suggest that, and also your caltracs.
MrRocky
Joined: Thu Dec 17, 2009 10:30 pm Posts: 4731 Location: perth
 Posted: Mon Oct 05, 2020 1:53 pm |
I ran 32"s no body lift, no susp lift, no gaurd chop If your wheel offset and suspension is setup correctly there is no issues. My current zook has 31"s no chop no body lift
_________________ ...
MUDFROG
 Posted: Tue Oct 06, 2020 9:01 pm |
So if I'm to swap transfer gears for some other ones, I have to get a complete sj70 leafy case? a jackshaft and a rock ring? where would i fing them? will that bolt straight into the original one? any other parts required? I still don't really know what gears to run exactly..
Brenno
Joined: Thu Apr 22, 2010 11:30 pm Posts: 1000 Location: Hobart
 Posted: Tue Oct 06, 2020 9:27 pm |
be prepared for a $1500 upgrade FYI. $300 for ring, $1k for gears and if you are lucky case and shaft for $200.
MUDFROG
 Posted: Tue Oct 06, 2020 9:37 pm |
Brenno wrote: be prepared for a $1500 upgrade FYI. $300 for ring, $1k for gears and if you are lucky case and shaft for $200. slowly getting ready.. will the sj70 case once all setup with gears etc go straight in where the orginal case was?
Cozook
Joined: Thu Sep 11, 2008 11:30 pm Posts: 725 Location: Blue mountains.
Vehicle: 98 coily..Max.
 Posted: Fri Oct 09, 2020 7:58 am |
G'day all. Haven't spoken for a while but yo. I'm rollin a 98 coily on 30"s with stock transfer and two inch lift. Stock motor. This is my second coily.....i love em.......but. I wouldnt bother makin it a comp rig. For quick overnighters he's awesome.........loves fire trails and dirt and stuff. Not rock crawling. I have an rc truck for that.(axial scx10iii with sierra body  ) Finding unique rare...2 year model.... panels that you damage or repairing strut towers is not an issue with a leafy but you sir are the owner of a coily. Coilys are like are like the leafys younger softer brother that got edjumacated.... By the catholic church........ he walks and acts like a poof but he'll still have a go.....he just can't fight for shit. But......he gets the ladies. My coily does highway km's really comfortably compared to the leafys i've had......but tis still shit with hills,crosswinds,potholes,legroom,storage..etc. If you love sierra's you have a screw loose....... If you love coily's you have a screw loose and no spares...... P.s. even wheel bearings are different.... WELCOME......
_________________ Suzuki...four wheel jive!
98 coily...Camping rig.
alien
 Posted: Fri Oct 09, 2020 10:53 am |
LOL!
MrRocky
 Posted: Fri Oct 09, 2020 6:25 pm |
Coilys are defenately the pinicle of suzuki engineering and can be seen in there capability and reliability
Gwagensteve
 Posted: Sat Oct 10, 2020 8:45 am |
OK, I"m in front of a computer. Sorry, this week didn't pan out as planned so I hadn't had the chance until now.
I'm probably going to hit you with a bunch of questions you hadn't considered or don't think are relevant, but I have my reasons. Please don't think I'm being patronising or belittling you - I don't know anything about you, I'm only trying to work on what you've told us, please don't take offence. I might sound like an old bloke telling you you need to slow down and take it easy, but I genuinely want you to be able to get the best out of your car.
When you said "kinda new to all of this" which bit are you new to? 4WDing altogether, or owning a suzuki (but you're used to other 4WD's, or modifying a Suzuki specifically but you've had other 4WD's with light modifications?
If you're new to 4WDing, you absolutely don't need a Sierra on 31's with gearing and a rear diff lock. That's like the first time you go around a race track being put in a touring car - the learning curve is too steep. You'll most likely put it on it's side or break it (or both) and it'll get scary and expensive quick.
Find other local Suzuki drivers. I'm not sure what the club situation is around you, but going 4WDing with "big" cars like patrols and cruisers is a pretty intimidating/awful experience a lot of the time. They don't work the same way, you can't drive a Sierra the same was a big car, and your suzuki is most likely already more capable than 99% of big cars, just in a different way. It's hard to learn how to get the best out of your car when you're surrounded by people "sending it" in their big cars.
To start with, work on the small things- take the swaybar off, put diff and transfer case breathers on it, buy a compressor and tyre levers, learn about the effect of low tyre pressures, learn how to put a tyre back on the rim if it's fallen off. Concentrate on learning how to pick lines that keep the wheels level, gear selection, staying away from the clutch, all the skills that allow you to slow the car down as much as possible and stay in control.
Why start like this? Because you need to get a feel for what the car is telling you. If you make a small change from standard (like letting 4psi out of the tyres, or finding some small tyres cheaply second had that are a little bit more aggressive) every thing you do to the car will feel like it's transformed it. you'll do things easier and feel a little bit more in control. Then, you can step back and say "I like the way it did XXXX, but I'd like it to do XXX little bit more easily, and to do that I need a *slightly* lower 1st gear. so you're unlikely to regret your decisions, and you'll be in the best position to make the right decision for your terrain and driving style.
The best driven cars I've ever seen are close to standard cars with drivers who have put years into driving them. They can make them do amazing things. The worst driven cars I've ever seen were inexperienced 4WDer's with 80 series landcruisers (when they had just come out) with twin diff locks. They'd just drive around with the stereo on and windows up with both diff locks in with absolutely no idea where there car was or what it was doing.
So, I see you're in Mackay. I'm pretty ignorant about the local 4WDing you have around you, but I do have a fair amount of experience with the coil sierra and the sort of modifications you're suggesting. As I'd said, I don't think Cromo front axles are readily available, but I'm also not sure you're going to need them, and certainly not in the short term. 6.5's will feel very, very low.
I'd consider 4.1 transfer gears. with 31's it will feel very slightly taller geared on road, but it'll be OK, and off road will be pretty usable in all conditions. This means you can and will use 1st low rather than it being useless except for the 1% of the time when you're trying to crawl a super technical obstacle.
Personally, I'd consider putting in a WT case and just driving it on that with whatever tyres you currently have for a little while. The gearing will feel quite a bit lower on and off road. It will give you a feel for how much more reduction you might want. Basically, over what you have now, it will feel like you have one whole gear lower than your existing first gear in low range. If you then swapped to 6.5 gears, it will feel like you have a whole three gears lower again. You'll likely think that's too much and you'll get sick of being "between ranges" - i.e constantly between low 4th (I don't recommend using low 5th) and high 1st.
Here's another bit of left-field philosophy. We're not 4WDing because we have to, we're doing it because it's a fun hobby. For me, I spend a lot of time working on my car trying to make it better at some thing or another, but when I'm driving it, it's with other people who have cars which are similarly capable. It's a community. The problem is, we've created super capable cars which are, frankly, boring to drive on most tracks. The group of us with the super-built cars only take them out a few times a year, because there's very little terrain that they're suited for.
Which brings me back to who you're driving with and what terrain you have around you. The most fun you can have is when the car is *just* capable enough to drive the terrain you have around you, and you have a group of friends to drive with who have cars that are all about as capable as each other. Nobody wants to be the one guy getting stuck all the time, but also, you don't want to be the one guy who never has any trouble - you spend a lot of time waiting for everyone else to recover etc. As for 4WDing by myself, I don't do it - it's never much fun and the consequences of a simple mistake are just too great.
I know that's a big chunk to read that's not answering specific questions about what to do with your car, but it's also sort of why only you can really answer those questions. Lots of people will tell you a coil sierra is no good (and I'm a renowned coil hater) but that depends on where you're standing. What you're describing is the path to take a coil sierra about as far as possible with bolted on parts. That will make for a capable car but you will be dealing with the big coil sierra problem - they drive onto their back door and lift front wheels way in the air. If your terrain doesn't make this a problem, then the car will likely suit your needs pretty well. If however, that starts to become a limitation there's very little you can do to reduce it without custom fabrication.
MUDFROG
 Posted: Sat Oct 31, 2020 9:43 pm |
Gwagensteve wrote: OK, I"m in front of a computer. Sorry, this week didn't pan out as planned so I hadn't had the chance until now.
I know that's a big chunk to read that's not answering specific questions about what to do with your car, but it's also sort of why only you can really answer those questions. Lots of people will tell you a coil sierra is no good (and I'm a renowned coil hater) but that depends on where you're standing. What you're describing is the path to take a coil sierra about as far as possible with bolted on parts. That will make for a capable car but you will be dealing with the big coil sierra problem - they drive onto their back door and lift front wheels way in the air. If your terrain doesn't make this a problem, then the car will likely suit your needs pretty well. If however, that starts to become a limitation there's very little you can do to reduce it without custom fabrication. Sorry, didn't turn on notifications for post, just seen it now. No offence taken mate, very helpful, informative information, much appreciated. New to modifying a Suzuki, first time owning one, have done a bit of 4wding yes, and just starting with all the light small mods, tires, body lift, transfer case, cradle have been ordered/already have. and will go from there then, get a feel for it once that's all installed, and yes depending on terrain with lockers etc.. for diff breathers in sierras yous just run them on up to the engine bay on the fire wall correct?
Gwagensteve
 Posted: Tue Nov 03, 2020 10:16 am |
Yes, up on the firewall is fine. Note the best way to run breathers is to shorten and tap the existing breather hole in the axlehousing to 1/8" BSP and then fit a barb to suit ~1/4" fuel hose or similar. Most hydraulic/hose stores like Pirtek now sell a generic multi-purpose hose that's suitable. Don't use PVC or garden hose, it will become brittle and fail. A split breather hose is worse than not having breathers at all.
MUDFROG
 Posted: Tue Nov 03, 2020 2:09 pm |
Gwagensteve wrote: Yes, up on the firewall is fine. Note the best way to run breathers is to shorten and tap the existing breather hole in the axlehousing to 1/8" BSP and then fit a barb to suit ~1/4" fuel hose or similar. Most hydraulic/hose stores like Pirtek now sell a generic multi-purpose hose that's suitable. Don't use PVC or garden hose, it will become brittle and fail. A split breather hose is worse than not having breathers at all. cheers mate
[ 17 posts ] |
Users browsing this forum: No registered users and 57 guests
