It is currently Mon Oct 05, 2026 4:17 am
Vehicle: 1999 Jimny
Post Posted: Sun Oct 04, 2009 10:49 am
Just to make sure I'm clear......... On what I've read so far.
1, Standard rears give you 2" lift on the front??
2, Leaving the rear mount standard and extending the chassis , how far does the Diff move forward??
3, with extending your chassis do you use a standard length shackle or does it need to be longer?
4, How far does a FUR with Lux springs move your diff back?????
5, Has anyone got the year of lux needed?
6, The unlikely one........ length of the lux spring.
I need to stretch a few extra inches out of the wheel base for the Frankenrolla. Be nice for a bit of good flex as well.
Post Posted: Sun Oct 04, 2009 11:11 am
1 not always depends on how its set up between spring and shackle mounts
2 mine moved about 25 mm
3 you can use either, I'm using extended but I set it up like that it gives me no/ little more lift really just more droop and a better shackle angle
can't help with the lux shit sorry mate
Post Posted: Sun Oct 04, 2009 2:29 pm
timmy or bluesuzy used 323 springs or something in the rear...
Post Posted: Sun Oct 04, 2009 2:56 pm
I think bluesuzy is using corolla springs in the back now. The 323 ones got a little bent.
Post Posted: Sun Oct 04, 2009 3:13 pm
i cant believe how many different ways there are to do a ruf
Vehicle: 1999 Jimny
Post Posted: Sun Oct 04, 2009 4:34 pm
Fark me side ways........ Just threw a set or Rolla springs away....
KE70 springs work (panel van have leaf springs)??
Post Posted: Sun Oct 04, 2009 4:36 pm
KE70 has leafff :roll:
Vehicle: 1999 Jimny
Post Posted: Sun Oct 04, 2009 6:00 pm
ke70 panel vans ARE leaf, what you think sits on my Suzi chassis.... KE70 sedans are coil....
Post Posted: Sun Oct 04, 2009 6:07 pm
I stand corrected.. :oops:
Vehicle: 1999 Jimny
Post Posted: Sun Oct 04, 2009 9:20 pm
I now have 2 sets of Corolla springs again......... anyone want a cheap set??
Oh & Disregard questions 5&6..................
Post Posted: Mon Oct 05, 2009 1:31 am
how much for the rear springs mate? i'd be keen
Post Posted: Mon Oct 05, 2009 9:34 pm
My rears are ke30/55main, ke70 main cut to size, then rest of ke30/55 pack.
Ke70 wagons springs are mega long. Longer then ke30/55's
I did run 323's. I snapped one.. Farking hard to find. so went rolla's..
Vehicle: 1999 Jimny
Post Posted: Mon Oct 05, 2009 10:54 pm
how far did your diff move back???????????
Post Posted: Mon Oct 05, 2009 11:39 pm
15mm.
Rolla springs are standard 500mm pinhole. Perch's and plates 15mm redrilled. Rear shackle mount is cut off and remounted. Also running double size shackles.
Your wheel base is 40mm out yes?
Just redrill your perch's and plates. Is this going to be an onroad or offroad corolla crossover?
Vehicle: 1999 Jimny
Post Posted: Tue Oct 06, 2009 12:37 am
will be used both on & off road, short distance only to work.
Want to sneak 50-60mm extra into the wheel base so the tyres won't scrub on turns. I plan to cut the guards anyway for the extra wheel diameter. will need to find some good flares as well.
Post Posted: Tue Oct 06, 2009 1:16 am
So possibly (jeep) bushwacker flares on a 4wd corolla. This will be the 1st :lol: :lol:
Users browsing this forum: No registered users and 183 guests
