Joined: Mon Sep 13, 2010 10:13 am Posts: 348 Location: Hervey bay QLD
Posted: Thu Jul 01, 2021 8:38 pm
Are there any main differences between the diffs sj40/sj50 apart from ratios, have just picked up a couple of Zuke”s and side by side comparison they look interchangeable, being a narrow rack or am i dreaming
_________________ Sik as drover, 32" mongrels, 4age 20v, 2" sus, 2"
You’ll need to clarify what you mean by “diff” The completed axle assemblies will interchange with the appropriate yoke fitted to the driveshaft and some messing with u bolts and spring plates.
The front and rear axleshafts will interchange.
Front knuckles will interchange along with front brakes assuming it’s a disc brake SJ40.
The housings, diff centre and ring and pinion gears are unique between each model and do not interchange. Sj40 is considerably smaller.
Users browsing this forum: Google [Bot] and 85 guests
