It is currently Thu Nov 05, 2026 1:17 pm
Vehicle: Suzuki Jimny 2010
Post Posted: Fri Jan 14, 2022 8:52 pm
Can anyone suggest supplier of trailer hubs to suit Suzuki wheel pcd? I have LM11949/67048 bearings.
Apparently redrilling is not legal, but my hubs not big enough diameter anyway.
'10 Jimny, M18A, 80mm lift kit, 215/75R15 on ROH mags, rear disk brake conversion and front disk vented upgrades. Air Lockers front and rear; cruise control; 70L fuel tank. Castor corrected Radius Arms, rear panhard rod raised mount, steering damper; bash plates transfer, radius arm, shocks, dual batts, headers, winch, rock sliders, custom aluminium roof rack on fitted tracks, Atoto head unit, LED headlts & HID 7" driving lights; 105Amp alternator to feed all the lights.
Vehicle: 91 Tin Top
Post Posted: Mon Jan 17, 2022 1:14 pm
Pretty much any of the eBay sellers will get them for you.
From memory I got my lazy axle hubs from Marshall Engineering in VIC.
And I got my braked hubs from Sunee (or one of those eBay guys).
Both where Suzuki (F100) stud patterns and both on the same LM bearings as you have.
I’m sure you’ll find local guys in Brissy that will get them in for you too.
I grabbed some bits and pieces from Trailers R Us in Northgate a while ago, they seemed pretty keen to help chase parts for me.
Post Posted: Mon Jan 24, 2022 10:17 am
Thanks pete_79, I tried two online and they could not supply. I will give the Northgate guys a shot.
Post Posted: Mon Jan 24, 2022 11:03 am
I got mine from couplemate but had to go 10” drums with parallel bearings.
If you are building a trailer you may as well fit brakes anyway because most suzukis have very low unbraked limits
Post Posted: Wed Jan 26, 2022 12:30 pm
Spot on shep. Two big mobs here in Bris could not supply and were not interested (guess they are not manufacturers), but Couplemate offered to make up a set using an existing design with 139.7pcd blank, and fitting Jimny size studs for me. Not cheap but with new Japanese bearings. And they squeezed me in the production line to get them this week, or else it was a month or two.
It's an existing trailer that I wanted to have Jimny wheels on for spare wheel interchangeability. Only carries my roof top tent and whatnots under that, so not a heavy unit by any means. I thought about brakes but got lost with the options and decisions. Basically I wanted electric, but not drums (I converted the Jimny rear drums to disk to get away from the mud and rust mess after every deep puddle). The it keeps going with maybe heavier axle, heavier springs ......................
Users browsing this forum: No registered users and 9 guests
