It is currently Thu Sep 24, 2026 5:33 am
Vehicle: 1992 1.3 Sierra tin top
Post Posted: Mon Mar 28, 2022 8:02 pm
Hi, I am having an issue with the wipers on my 1991/sj70. When you turn the Wipers on to wash the windows the fluid pours out under the dashboard on the driver's side onto the fuse box and then the driver's side floor pan. Has anyone else experienced this and can suggest a fix? I'm hesitant to pull the dash out. The previous owner attached a new nozzle to the bonnet and re-routed it, so I'm thinking this isn't an easy fix. Thanks
Post Posted: Tue Mar 29, 2022 6:40 am
You are going to need to pull the dash, likely a split in a hose or not connected at all. Pulling the dash isn't hard, just label all the bolts and take pictures
Users browsing this forum: Google [Bot], Google Adsense [Bot] and 187 guests
