It is currently Fri Nov 13, 2026 2:54 pm
Post new topic Reply to topic  [ 48 posts ]  Go to page Previous  1, 2
Post Posted: Tue Mar 08, 2011 11:53 pm
Thats a CRAZY CV angle! 8O
I've adjusted the steering lock stops,
to help me resist turning it too far when articulating.
Steering angle of cv is way bigger than that caused by suspension movement
Post Posted: Wed Mar 09, 2011 12:03 am
8O i would look at getting some diff drop brackets... i think i can hear your CV's crying in pain from here.
Post Posted: Wed Mar 09, 2011 12:14 am
I may do, but only if I have to.
Diff drop only helps with the travel changes angles.
Steering angles will still be greater.
Think I will learn not to boot it when turned hard 8O
Post Posted: Wed Mar 09, 2011 4:23 am
Hey chris. I got my GV snorkel and diff drop brackets from GIZ international and they Diff Brackets were only $90AUD plus post. Snorkel was $248. They only rotate the diff down 1 inch but you can clearly see the difference it makes. Well worth doing if you have more than 50mm of lift.
Post Posted: Wed Mar 09, 2011 4:27 am
My money tree ran out.
Will have to drive carefully now, and get diff drops sometimes in future.
Got to pay for rear disc conversion and idler arm first :O)
Post Posted: Wed Mar 09, 2011 6:05 am
When did you fit em??
Wheeled it since fitment??
Post Posted: Sat Apr 16, 2011 12:01 am
I'd like to see pix of drop brackets.
Are they holding up well.
There is a great deal of them available, but prices are high ish.
Ones I have seen appear to be high quality.
Don't want cheap, I want value for money :)
Post Posted: Fri Apr 22, 2011 9:46 am
what should i use to space down the the strut mounts when i flip them? would a couple of washers packed in there do the job or do i need something more substantial?
and what length bolts do i need?
cheers
alex
Post Posted: Fri Apr 22, 2011 9:50 am
cheers
alex
I used 3 washers on each bolt.
I used bolts I had in my spare pile, which are a bit too long.
But thats better than too short.
Bolts need to be at least the thickness of the plate longer.
Post Posted: Fri Apr 22, 2011 10:12 am
ok, roughly how long were your bolt? just general bunnings spec washers? high tensile bolts?
Post Posted: Fri Apr 22, 2011 10:18 am
I used high tensile, sounded best to me,
tho I am not an engineer or mechanic.
I think bolts were roughly 30mm long.
Bunnings washers will be fine,
as long as they add to right thickness.
Post Posted: Fri Apr 22, 2011 10:22 am
should the washers sit at the same level as the outer ring or should they sit a little higher?
Post Posted: Fri Apr 22, 2011 10:33 am
I reckon same level, so its supported evenly.
Higher would still work, but all pressure would be on the washers.
Washers are to stop the mount collapsing if too tight,
and to stop rim of mount digging in to tower.
This is what I understand.
Post Posted: Fri Apr 22, 2011 10:36 am
yeh thats what i thought too. ok well i'll give it a crack next week and see how it goes. thank you for you help
Post Posted: Thu Apr 28, 2011 8:44 am
pics of mine for others reference. i didnt flip the washers
Post Posted: Thu Apr 28, 2011 8:55 am
i'd be looking at putting some larger washers top & bottom.... definitely the top.
Post Posted: Thu Apr 28, 2011 9:28 am
whys that? bolts are same size as the originals, if not bigger
Post Posted: Thu May 25, 2023 6:13 pm
:thefinger:
Has anyone done this with aftermarket tops?
Kyb or kelpro or similar and had any issues?
This cars a keeper, so figure I may as well put new things in when I’m doing it rather than be a typical zook tightass.
Users browsing this forum: Google [Bot] and 83 guests
