It is currently Fri Sep 25, 2026 2:54 am
Vehicle: 2004 SWB J20A Grand Vitara
Post Posted: Sun Jul 16, 2023 6:11 am
2004 SQ420 / J20A SWB / 2.0lt / Auto
Trying to sort this out, I don’t have a scan tool that works with it (OB2 plugs in but doesn’t read)
Seems to drive OK, if a little surging when accelerating and bogging down when planting your foot.
Has irregular idle / slight miss - (see video - https://drive.google.com/file/d/17v3dR-j8chbdX_pX_WKMjBgcMPkKMEY6/view?usp=sharing
(Also a few pulley squeaks which I will fix)
Engine light has NOT come on (unless I pull an injector lead and make it come on)
Has new injectors, coils, coil tubes, plugs.
Throttle body has been cleaned.
EGR valve pulled out and cleaned
New fuel pressure regulator.
New idle control valve
Full service with oils and filters
Ordered a O2 sensor - on it’s way.
Yes I know, throwing parts at it is not the solution but I’ve got nothing better to do - keeps me poor and out of the pub :)
Vehicle: Suzuki Grand Vitara 04 manual
Post Posted: Mon Jul 17, 2023 11:11 am
Check for flat spots on the throttle position sensor
Post Posted: Tue Jul 18, 2023 12:38 am
Has the fuel filter been replaced? What's the fuel pressure like?
Post Posted: Tue Jul 18, 2023 6:29 am
Thanks - yes, it was bad but the new fuel pressure regulator fixed it and improved the idle - seems good now but I don't have any way of measuring it.
Still has the miss though.
Post Posted: Tue Jul 18, 2023 6:31 am
Thanks - I wouldn't have thought the TPS would cause a miss at idle, maybe while accelerating, but will check it.
Post Posted: Tue Jul 18, 2023 11:02 am
You could have more than one problem.
Users browsing this forum: No registered users and 142 guests
