It is currently Fri Jun 05, 2026 3:10 am
Vehicle: 95 sj70 and 78 lj81
Post Posted: Fri Jun 13, 2025 5:23 pm
For those that have done it, what do l need to grab from the donar cappuccino
Vehicle: 1985 Holden Drover 1.3litre
Post Posted: Sat Jun 14, 2025 8:34 pm
What are you swapping into?
Post Posted: Sun Jun 15, 2025 4:58 pm
LJ50
Post Posted: Mon Jun 16, 2025 5:28 pm
I'd grab all the wiring, cluster, ecu, engine, gearbox and whatever else you think you want.
It has been done before i think.. I only know of Kym and Gwagensteve, but thousands of years ago. Can try contact them. Unsure if they were from a cappa
https://www.instagram.com/kymbo7893?utm ... c0MzIxNw==
memberlist.php?mode=viewprofile&u=165
Post Posted: Tue Jun 17, 2025 8:55 am
I’ve done two f6a swaps but into an SJ70 and SJ40. Lj50 is going to make things much more complex.
The cappuccino gearbox has a huge shift extension on the back that’s not easily managed and will be a big problem for an LJ.
VSS will be harder with an LJ cluster.
A custom gearbox mount will be required as the LJ doesn’t have a mount down the back.
I haven’t seen a 50 f6a swapped but I’ve seen 80’s where there is more room for the motor.
It’s going to be a challenge to keep the 50 bonnet.
Post Posted: Tue Jun 17, 2025 6:51 pm
Thanks Steve, looks like the F6A that l had lined up has fallin through.
Ok back to your comments.
. The huge shift thing - can that be removed and put a top loader like you can on a vitara box?
Custom mounts is my middle name as l had to with the LJ81 build l did so no fab issues there
Bonnet wise l will be using an80 bonnet which l know will be tight just like the G16 was.
I am also looking at a K10C which l believe would work but need to make a bell housing adapter also doable. Thoughts?
Post Posted: Wed Jun 18, 2025 7:42 am
I think the k10c is enormously tall as it was designed for the wagon R which had a very tall cowl. Inlet manifold is plastic and sits up super high
No we found no solution for the shifter. We shortened it but it didn’t work properly and a kei sierra gearbox was sourced.
Post Posted: Thu Jun 19, 2025 5:14 pm
Again thanks Steve
More spit balling daewoo matiz? Maybe? Also l’ve just been looking at the cap manual. I can get my head around the gearbox linkage. Do you have any photos of one at all
Post Posted: Mon Dec 08, 2025 1:01 pm
Little update, I’ve managed to Aquire what appears to be a late model F6A (with EFI). The gearbox that came with it is and AWD from an Alto which won’t be used.
1. Now can l find what vehicle it was actually from.
2. What gearbox could l fit?
3. Is there anywhere in Aus to get engine rebuild kits and parts?
Post Posted: Tue Dec 09, 2025 8:51 am
All F6a’s are EFI as far as I know.
Odds are it’s from an Alto?
You’ll need a gearbox from a 660cc Sierra. (The last 660cc sierras were K6a, unsure if the bellhousing bolt pattern is the same.
The bolt pattern does not match the F8A/F10A.
Parts are not readily available locally.
Post Posted: Thu Dec 11, 2025 12:29 pm
Thanks Steve, a 660 sierra! Guessing that’s an import operation then?
Post Posted: Thu Dec 11, 2025 3:24 pm
Correct. There are a few around. Many are F5a but I think the bellhousing pattern is shared.
Vehicle: LJ50 , LJ80Q-II
Post Posted: Mon Dec 15, 2025 11:45 am
In Nz , but pretty sure this is the gear box you are looking for
https://www.trademe.co.nz/a/motors/car-parts-accessories/suzuki/listing/5679206264
Post Posted: Mon Dec 15, 2025 2:11 pm
That’ll do it.
Post Posted: Tue Dec 16, 2025 12:27 pm
Drive shaft is flogged out, would it fit in mu suitcase?
Post Posted: Tue Dec 16, 2025 12:46 pm
You’ll want a large suitcase.
A large duffel bag would be better.
Post Posted: Tue Dec 16, 2025 12:47 pm
I think the output shaft spline is the same as 1.0 litre from memory. Jackshaft is very close to 1.0 litre
Users browsing this forum: No registered users and 24 guests
