It is currently Wed Oct 07, 2026 11:41 pm
Post Posted: Mon Oct 12, 2009 12:35 am
so i finally got 6.5 transfer gears and now need to reinforce my transfer
has anyone ever used the roctoy design transfer ring?? the one off outers.
what do people use and if you can post where to get them for
Vehicle: MY2019 Jimny
Post Posted: Mon Oct 12, 2009 12:42 am
I used a mighty kong cradle, but many people have used the RT ring with great results too.
Go to the for sale section on outers, they are for sale there.
Post Posted: Mon Oct 12, 2009 12:43 am
i haven't bothered to strengthen anything, occasionally i blow a mount, but i
have shitloads of them so i dont mind.
i recon a cheap part as the weak link is the go and it only takes 5min to change them.
i am a fairly sedate driver though so you hoons might have problems. :thefinger:
Post Posted: Mon Oct 12, 2009 12:54 am
Go the RT ring, a cheap part that takes 5minutes to fix ain't a new case and new gears to go along with it. I don't think the lifetime guarantee would cover the whole case failing.
An ounce of prevention v a pound of cure.
I've seen people split cases with Series I and II Rockhoppers, 6.5 would eat them up at a very quick rate.
Post Posted: Mon Oct 12, 2009 1:22 am
all the busted cases i have seen have had solid mounts. i haven't heard of a case failure when standard mounts are used.
Post Posted: Mon Oct 12, 2009 2:05 am
I run a rocktoy ring and recomend em
 Profile YIM
Vehicle: 1993 Sierra 1.6 efi Vit motor,
Post Posted: Mon Oct 12, 2009 10:52 am
I agree with Shep, I have had 6.5 gears for over a year now with no problems apart from a couple of busted mounts (weak link). I don't thrash the zook but do drive some tough tracks though. I also use the zook as a daily driver.
Adventure before Dementia
Post Posted: Mon Oct 12, 2009 7:33 pm
I highly reccommend the witches hat transfer mount.
Take one of the bolts which hold your front bar on, cut a couple of bits out of the base of a witches hat you found laying in the grass nearby, combine for one booty fab transfer mount that has been holding quite well that you couldn't be bothered fixing properly. :lol:
Users browsing this forum: No registered users and 174 guests
