It is currently Tue Oct 06, 2026 6:32 am
Vehicle: 90 WT ST Locker, Tyres
Post Posted: Wed Oct 14, 2009 10:24 pm
hey guys i noticed a few weekends ago when i was out at glasshouse when i was on a steep hill raping it or getting air born and front wheels picking up while raping it, it would start to die or starve for fuel. wat causes this and can it be over come ?
would a decent electric fuel pump over come this ? and do i need to take it easier ?
thanks aaron
Post Posted: Wed Oct 14, 2009 10:48 pm
2 word`s. Get a Grand Vitara.
Post Posted: Wed Oct 14, 2009 10:54 pm
lol never
Post Posted: Wed Oct 14, 2009 10:55 pm
Thats four :lol:
Post Posted: Wed Oct 14, 2009 10:59 pm
joseph wrote:
Thats four :lol:
4 Gv`s? that`s like, 2 3som`s 8)
Post Posted: Wed Oct 14, 2009 11:04 pm
getting air hmmmm
Post Posted: Wed Oct 14, 2009 11:10 pm
v.w.dave wrote:
getting air hmmmm
You should try it... :P :P :P :P
Post Posted: Wed Oct 14, 2009 11:16 pm
Get used to it or upgrade to efi.
Post Posted: Wed Oct 14, 2009 11:26 pm
hmmm i see so an electric fuel pump wouldnt do anyting ?
Post Posted: Wed Oct 14, 2009 11:45 pm
the only experience i personally have with electric fuel pumps on zooks is on my mates. It was on there when he bought it. He constantly had fueling issues so replaced it with a standard mechanical pump and he never had another problem.
If the stock pump is working correctly i wouldnt change it.
Mine used to drown itself in the same way you describe, really bad when bouncing the front up ledges. I was told its actually the carby flooding the engine and i dont see how a different pump would change this.
I never tried to fix it though, just went straight to 1.6MPFI.
Post Posted: Thu Oct 15, 2009 12:09 am
i see no worries, think i will just approach things a bit differently.
thanks aaron
Post Posted: Thu Oct 15, 2009 12:10 am
thanks aaron
Faster!!! :P :P :lol: :lol:
Post Posted: Thu Oct 15, 2009 1:08 am
thanks aaron
My Father gets airborn on a regular basis (3rd gear low on 31's fast enough?), and has no problem with the carby starving. He only gets problems on really steep hills (as I did as well).
Sorry couldn't resist, dad airborne on the weekend... hehehe
Steknig, why get a GV when you can just nick the motor from one :wink:
Clearance Hole Technology :P
Post Posted: Thu Oct 15, 2009 1:11 am
You only got a toy 1.6 tho, 2.5 V6 that`s the way to fly!! :rambo:
Post Posted: Thu Oct 15, 2009 1:16 am
Put one in your Sierra... c'mon you know you want to :twisted:
SJ625 FTW!!!
Post Posted: Thu Oct 15, 2009 1:42 am
Dot won`t let me, been down this path, 2.00 tho & was 10yr ago.
don`t think thay will have changed their mind`s about it, it would have to be a Lwb. 8)
Post Posted: Thu Oct 15, 2009 2:03 am
Don't know about a H25, but I have heard of an engineer who reckons he'd pass a H20 in a SWB Sierra....
Sorry to the OP, getting off topic here :oops:
Post Posted: Thu Oct 15, 2009 2:07 am
I think we will need to talk soon..
Post Posted: Thu Oct 15, 2009 2:31 pm
SJ625 FTW!!!
Does steknig have wheels?
Vehicle: I drive your mum
Post Posted: Thu Oct 15, 2009 2:36 pm
Basically a carby uses gravity to work. Fuel is supplied to the float bowl through the neddle and seat valve. When the car is level or fairly level this works fine, the bowl is kept at the correct level by the action of the float on the neddle and seat balve. But once we throw in some angles, the design of the float bowl and the float itself become less effective. Then end result is either the neddle adn seat valve staying open causing the fuel level to get too high and spills over into the carby through the float bowl vent (usually when climbing), or the carby can starve for fuel as the fuel moves away from the jets (not really an issue with zook carbys).
Layto....
Post Posted: Thu Oct 15, 2009 9:45 pm
cheers.
Post Posted: Fri Oct 16, 2009 10:41 pm
For really BIG air time in a Zuke, you need one of THESE!
Post Posted: Sat Oct 17, 2009 11:45 pm
Had the same issue today. Going up a step hill with a small step, bounce, snuff, right at the critical time when you need to punch over the step. Just another zuk charateristic to deal with.
SS
Users browsing this forum: gbcrown, Google [Bot] and 165 guests
