It is currently Sat Oct 03, 2026 8:07 pm
Vehicle: SJ80
Post Posted: Thu Oct 15, 2009 3:48 am
I know that you can get an ARB air locker for the rear diff of a coily. I believe this is the same P/No. as a leafy rear locker.
I'm pretty sure that the front diff in a coily has only 2 spider gears as opposed to 4 in the leafy. From what I understand, ARB don't do a front diff for the coily as the market is too small.
My question is this:
Can anything be swapped/modified from a leafy front diff into a coily front diff to allow a leafy front air locker to work within the coily?
Thanks for reading,
Brad.
Post Posted: Thu Oct 15, 2009 4:17 am
put hilux diffs on it....
Post Posted: Thu Oct 15, 2009 8:50 am
i thought coily centers/3rds were real different to leafys and the axles are like 1L axles...
Post Posted: Thu Oct 15, 2009 10:13 am
you can definately get an air locker for the rear of a coily as I have a coily diff and air lock in the back of my leafy.
as for the front cant help you
Post Posted: Thu Oct 15, 2009 10:56 am
a friend of mine bought 2 front auto lockers. I'll see if he still has 1 layin around,
Post Posted: Thu Oct 15, 2009 11:42 am
normal sierra diffs, front or rear, have a 10 bolt ring gear pattern. the coily front though is unique in having an 8 bolt pattern.
Post Posted: Thu Oct 15, 2009 1:33 pm
I have heard of a Jimny front airlocker being moded to suit. I Don't know anything about it myself, just remember reading it somewhere. Maybe have a search around the interwebs.
Clearance Hole Technology :P
Vehicle: SJ80, SE416
Post Posted: Thu Oct 15, 2009 5:07 pm
Same, but I heard a Vit one can be modded.
Post Posted: Thu Oct 15, 2009 6:48 pm
a vit/ sierra front. to mod one you would have to re-machine and drill the bolt pattern for the crown wheel. becuase there will be overlapping holes this can lead to movement and stress failures of the cap. plus, there is no way in hell it would ever be warrantied. but if you got one second hand cheap it may be worthwhile. in the past i have converted coily fronts to use a standard sierra centre with 5.1's and used a non modded locker.
Vehicle: SJ80
Post Posted: Thu Oct 15, 2009 7:18 pm
What's involved with that? Is it component swapping or fabricating from scratch?
Vehicle: SJ80
Post Posted: Mon Oct 19, 2009 1:05 am
Ordered a rear diff lock yesterday - can't wait to test it :D
Any further comments or suggestions for my previous post?
Post Posted: Mon Oct 19, 2009 1:12 am
requires a sierra centre, knockles and steering, and some machining of the hubs or fitment of sierra outer axles.
Vehicle: SJ80
Post Posted: Mon Oct 19, 2009 2:59 am
Cheers... gives me a plan of attack!
Users browsing this forum: No registered users and 160 guests
