It is currently Wed Oct 07, 2026 9:17 pm
Post new topic Reply to topic  [ 48 posts ]  Go to page 1, 2  Next
Post Posted: Fri Oct 16, 2009 12:10 am
my car is stuck in the middle of our side street and it wont turn on... no noise at all when key is turned... battery is working heater/ lights come on... no engine anything... its bout to be blocking traffic and its full of rubbish to take to the tip fuuuuuuck!!!! any ideas???
[quote="zookieboi"]has anyone really been far even
Post Posted: Fri Oct 16, 2009 12:12 am
Loose battery cable to the starter? Check over everything you've touched
Post Posted: Fri Oct 16, 2009 12:15 am
as above battery connections or starter motor
i have the same issue
give your starter a good whack with a hammer and turn over at same time does the trick for me:)
Post Posted: Fri Oct 16, 2009 12:23 am
as above say.. or
put a for sale sign on it and walk away... thats right keep walkin! 8O
Post Posted: Fri Oct 16, 2009 12:27 am
as above
where was your advice to sell it when i needed it
in the last month i have done uni joints, bearings, shocks, gasket among other things and thought sweet now to zook will be nice and reliable WRONGH now starter has shat itself can never win
Post Posted: Fri Oct 16, 2009 12:42 am
If its all plugged in and still doing nothing hit the started with a hammer or soming on the side it might be froze up.
Post Posted: Fri Oct 16, 2009 12:49 am
Lol scrawn you were right once the cable was loose then drove to shops thinking all good turned it off :( stupid! And now same again will try hitting it will it make a difference I on a hill at all?
Just got new starter today too!
Post Posted: Fri Oct 16, 2009 12:56 am
Tried hitting it nothin... I m stuck behind a coles... Fuck!
Post Posted: Fri Oct 16, 2009 1:00 am
Are you sure all connections are tight and making good contact? ie: clean and free of crap. What are the battery terminals like? Tight and clean also?
Post Posted: Fri Oct 16, 2009 1:07 am
roll start?
Post Posted: Fri Oct 16, 2009 1:16 am
The only crap on em is lol bits of metal from where my battery charger scratches it up... The bolts are on too tight for me to undo and the wire to the starter motor is tight at both ends... Looks clean... Lights and everything come on fine... But nothing from the motor...
Post Posted: Fri Oct 16, 2009 1:17 am
Tried roll starting it bu starter is doing nothing so motor won't turn over...
Post Posted: Fri Oct 16, 2009 1:19 am
Terminals are definitely tight on the battery posts? Do you have someone who could try jump starting?
If all else is ok, it must be the starter. Was it new or rebuilt?
Post Posted: Fri Oct 16, 2009 1:21 am
New apparently looks new...
is the start motor jammed against the ring gear? put it in 4th, handbrake off & see if you can rock & roll the zook forwards & backwards against the compression to un jam it.
im guessing it's on flat ground?
Post Posted: Fri Oct 16, 2009 1:25 am
think he said it was on a hill
Post Posted: Fri Oct 16, 2009 1:31 am
On flat ground now and it's tough to roll feels like there's the wheels are square if you know what I mean easy to a point hard then easy again will keep rocking
Post Posted: Fri Oct 16, 2009 1:33 am
Where are you Pete? Who did the starter? Sounds like something is holding on
Post Posted: Fri Oct 16, 2009 1:37 am
Out the back of coles union square in Brunswick yeah there's bursts of air being sucked into the carby and a knocking noise coming from the engine when I push it back in a straight line bout 4 or 5 every metre I push?
Post Posted: Fri Oct 16, 2009 1:39 am
Is it in gear? What sort of knocking noise?
Post Posted: Fri Oct 16, 2009 1:47 am
Makes the whole engine jump and something there makes the noise
could just be my noisy engine turning over... But haven't noticed it before...
Post Posted: Fri Oct 16, 2009 1:48 am
Where on the starter should I hit it I just found a rock...
Post Posted: Fri Oct 16, 2009 1:50 am
It was running hot on the way here anything to do with it?
thats the engine cranking over, if the starter was jammed it would be free now!
Post Posted: Fri Oct 16, 2009 1:51 am
HUH?
Roll starting doesn't involve the starter motor...
Post Posted: Fri Oct 16, 2009 1:54 am
Fuck... So must be dud connection from battery to starter which I can't undo to check got no tools... Or dud starter?
Post Posted: Fri Oct 16, 2009 1:57 am
Shit sorry too tired to think... Will give it a go...
Post Posted: Fri Oct 16, 2009 2:03 am
want33s wrote:
HUH?
X2 :roll: 8O
Post Posted: Fri Oct 16, 2009 2:07 am
Union square Brunswick?
Just hide in the bushes and leave the keys in the ignition - someone will have it started in no time.... you'll just have to run after them.
*sorry* , cheap shot I know :oops: Lived in Brunswick for a while - three out of three cars vandalised.
Users browsing this forum: No registered users and 193 guests
