It is currently Tue Oct 06, 2026 9:36 am
Post Posted: Sat Oct 17, 2009 12:51 am
My mate rolled his 2003 Hilux the other month, and bought it back off the insurance company. He has airlockers fitted into both diffs.
My mechanic tells my both my current diff centers are in pretty bad shape.
I was thinking of offering my mate somewhere around the $1500- $2000 mark for both diffs, drive shafts and his air compressor, and fitting them to my car - that fixes my current problem, and upgrades to airlockers which i was already thinking of doing.
So far my pro's/con's list looks like this
Pros:
Stronger driveline/diffs - sierra won't put much strain on it
Wider Wheel track - more stability
Lower center of gravity - more stability
Repairs (by replacement) both diff centers
Upgrade from no lockers to air lockers
?? Upgrades Braking with hilux brakes ??
Cons:
Put more strain on other parts of the car - transfer case, gearbox... where is the weakest link now?
More weight in the car - unsure of weight difference though
Requires Engineering prior to being registerable
Can anyone add to the list, or give me more information on what i've already listed? I've never done this before, and want to get all the info before i make the offer to my mate. last time i was talking to him he was looking at trying to rebuild the car and get it working again... (only real problem with the car is major body and panel damage - mechanically should be fine)
Thanks
1988 Suzuki Sierra (SJ50)
1.6L G16A (EFI) with Su
Post Posted: Sat Oct 17, 2009 12:58 am
A 2003 Hilux is not live axle it is IFS so it is no good to you
Post Posted: Sat Oct 17, 2009 1:06 am
this, plus it will stick out like dogs balls so you would need TAC approval.
Post Posted: Sat Oct 17, 2009 1:14 am
The above is true.
And that car in question has been flogged.
How do you think it got rolled in the first place?
Just a warning anyway.
Silver lux half way down.
http://forum.darwin4x4.net/viewtopic.ph ... a&start=30
And who in darwin will fit them and do the body work?
I would think at least $xx,xxx
Post Posted: Sat Oct 17, 2009 1:17 am
but yes do it.
I am going to. :D
'94 sierra
Thank-you http://www.locktup4x4.com.
Post Posted: Sat Oct 17, 2009 2:03 am
if ya need any sierra diff bits i have heaps. kreecha will probably have some for
sale as well.
Post Posted: Sat Oct 17, 2009 2:20 am
kreecha wrote:
The above is true.
Haha, thats the car that rolled...
I was in the car with him on the second bog (the one that starts with the words ".... and once again the silver lux gets stick again... i'm not even going try explain this one lol :wink: ")
never saw the first one
anyways, the lockers only got fitted about 12 months ago, but if theres going to be that much work involved, then i'll just stay with sierra ones and fix em up. Might have to pull my diff centers out one day and have a good look at them. Need to have a look at my rear uni joints too, its starting to rattle (about 3 days after changing my front uni joints...)
might hit you up shep for some diff bits when i work out what i need... never played with diffs before, but thats half the reason i bought this car, to learn mechanical type stuff...
Post Posted: Sat Oct 17, 2009 3:55 am
as 2stroker said though mate that any standard Hilux 1998 onwards has IFS independent front suspension. so it wouldn't be like a normal Hilux diff you see on other sierras. unless t had solid axle swap before hand.
Post Posted: Sat Oct 17, 2009 11:13 am
For the money you would be going to spend to buy the hilux diffs and then have them fitted by somebody, you'd be better off buying two new rear arb air lockers and compressor, double tough front axles, and have your centres rebuilt at the same time everything is being replaced. Should be able to pick up the air lockers and compressor for around the $2k mark or a little over, and double tough axle for around $600 - $800. To get your centres rebuilt, it's not that hard, but shop around as mechanics rates vary from workshop to workshop, but if you can, stick to someone you trust even if it costs a little more, because I've unfortunatly been in this trade for 20 years now, and have seen a lot of half assed work performed by so called licenced mechanics.
At the moment, with the aussie dollar being worth around 92 u.s cents, you may want to try and price the parts from the usa. You find it'll probably be cheaper than buying local.
Post Posted: Sat Oct 17, 2009 11:24 am
Poor bastard, 21 for me. :cry:
Post Posted: Sat Oct 17, 2009 12:05 pm
lol. Good to know I'm not the only one thats over it :)
Users browsing this forum: No registered users and 179 guests
