It is currently Tue Oct 20, 2026 12:26 am
Post Posted: Fri Oct 23, 2009 2:10 am
i want some new seats for my coily sierra and i was wondering if there was any that just bolted in
any ideas?
Post Posted: Fri Oct 23, 2009 2:18 am
coily seats fit :finger:
 Profile YIM
Post Posted: Fri Oct 23, 2009 2:24 am
thanks jimbo i ment something more along the lines of a race seat or 2
Post Posted: Fri Oct 23, 2009 2:27 am
I know I'm just fucking with ya my mate put gti seats in his leafy I think they bolt up the same as a coily someone my be able to confirm this?
 Profile YIM
Vehicle: SJ80, SE416
Post Posted: Fri Oct 23, 2009 3:44 am
No they aren't the same. I cut the top of my coily rails flat and bolted angle and flat bar to them to adapt to a race style seat.
Vehicle: SJ80
Post Posted: Fri Oct 23, 2009 5:16 am
Me too.
here's a couple of photo's of how I did my seats. I welded up a frame, cut down the coily rails and bolted them together. Be aware when you do swap them, that aftermarket seats are a lot wider at the shoulder area. I didn't have a hell of a lot of clearance left between the seat and the B pillar.
Vehicle: SJ80
Post Posted: Fri Oct 23, 2009 5:27 am
Other photo didn't work :?
Post Posted: Fri Oct 23, 2009 11:10 am
Tha one on the left has the strangest looking seat belt I eva seen!! 8O
Post Posted: Fri Oct 23, 2009 11:31 am
These aren't really gti seats though. Don't proper gti seats from a zook bolt up a lot easier?
Post Posted: Fri Oct 23, 2009 1:25 pm
And todays number is 7.
(dogsmakinga7)
Vehicle: SJ80
Post Posted: Fri Oct 23, 2009 1:36 pm
I put Swift Gti seats in my coily.
Ended up cutting out the front chassis/body seat mount, welding in some square tube. This allowed me to use the Swift Gti rails.
There may be easier ways of fitting them, by modifying the seat rails.
Never the less will not be a straight bolt in job. Fudging around with welding and drilling required.
The GTI seats are a little longer - the seat part, and the shoulder bit is wider as has already been mentioned.
I also changed over the seat belts for the GTI ones.
This may not have been such a smart move.
The buckle on the belt sits at a different hieght to the originals, and because the sides of the seat backs are closer to the B piller, is it a pain in the arse to fish out the buckle when you first get in and want to put your seat belt on.
On the plus side, GTI seats look great and are very comfy!
Vehicle: SJ80
Post Posted: Fri Oct 23, 2009 3:54 pm
Yeah... the most time demanding seat belt ever too.
Post Posted: Fri Oct 23, 2009 3:57 pm
gti seats in my leafy, all i had to do was drill a couple of extra holes.
if there is a will there is a way---- you may not have to weld new brackets is all i mean.
my leafy seats had M6 bolts holding it together where the gti ones have M8. so are a little safer.
Web wheeler extroadinaire
Post Posted: Fri Oct 23, 2009 5:22 pm
I reckon it's best to use the existing rails in the factory holes. If you are smart, you can use the factory rails and mounts, the factory seat belt mount on the rail (with a longer 7/16 UNF bolt), and not have to weld anything, or re-drill the body, which might make whatever you do easier to pass a mod plate inspection, and a whole lot safer.
Post Posted: Fri Oct 23, 2009 7:17 pm
thanks for the info guys
Users browsing this forum: Google [Bot] and 214 guests
