There is no part number on it at the moment so cannot compare.
fordem wrote:
Just a suggestion - try the Ryco Z464 that the listing shows for the 98~00 SV420.
The Ryco listing appears to be incorrect, the Z389 (as shown in your picture) has inlet & outlet pipes - which is what is used on the 98+, and the Z464 has threaded inlet & outlet fittings, so they probably have them reversed.
Thanks. Ill have to order another then. I was thinking that could of happened but wanted to check before I spend another 70+ on another wrong part!
Appreciate your replies guys.
