It is currently Fri Oct 23, 2026 9:50 am
Post Posted: Mon Nov 23, 2009 1:50 am
G'day,
Just got my mechanic to do the head gasket [vrs kit, new rings etc] (G16 carby 8v -- 190,000 kms) because a fair bit of radiator fluid was leaking into the oil, however after 1000km about 1 litre of radiator fluid per 500km is still ending up in the sump?
I've got no idea what it is? The I had the head crack tested, no cracks... any ideas? Perhaps a water jacket?
Just trying to work this stuff out before I take it back
1990 SWB Vitara
1997 Sierra
1991 Sierra *RIP 7/0
Post Posted: Mon Nov 23, 2009 1:54 am
Water jacket or I think someone (maybe royce) said they can crack in between the block and cyclinder sleeve. Sorry, but it is a big fix, well not really fix as such, new block. I assume they checked the head for flatness and straightness on the face of the head??
I just went back and looked at my old thread about my issue..it was actually built4thrashing that told me..scary now he has posted on here after me now :wink:
Post Posted: Mon Nov 23, 2009 2:01 am
could also be a welsh plug in the head.
Post Posted: Mon Nov 23, 2009 11:40 am
They may have not taken the motor out, so leveling/decking it may have not been an option...
Post Posted: Mon Nov 23, 2009 12:31 pm
It would be worth asking the mechanic if they measured the block. I have seen the gap between 2 & 3 get distorted from heat and the owner kept blaming the head without checking the block. Obviously a mechanic should know better, and this bloke probably does, but it doesn't hurt to ask.
Post Posted: Mon Nov 23, 2009 4:18 pm
Crossing my fingers it's a welsh plug.
If it's a cracked block/head, what would be the cheapest fix? New block? How much do they set you back...? :(
Ta for the info.
1990 SWB Vitara
1997 Sierra
Post Posted: Mon Nov 23, 2009 5:51 pm
If it's that far gone mate just find a 2nd hand complete engine from somewhere, even a shorty for that matter, you have everything else
Post Posted: Tue Dec 01, 2009 8:25 pm
Okay... turns out it was just moister left in the sump (the oil was drained, and the oil filter changed) but there must have been a pool of water that sat there. And the reason why I was losing fluid was because a faulty radiator cap.
Seems to be a good theory, the amount of milky substance is nothing like it was before. I'll just keep cleaning it off until I can dump the oil again.
Thanks for the help though :)
1990 SWB Vitara
1997 Sierra
Post Posted: Wed Dec 02, 2009 10:56 am
damn i have a g16b sitting it just got a blown head gasket but other than that it runs fine i just couldn't bin stuffed spending ova a grand to get the head when the whole motor has done 243000 so i got a low klm motor +i needed a new compressor for the air con.
Users browsing this forum: No registered users and 117 guests
