It is currently Fri Oct 23, 2026 12:32 pm
Post Posted: Tue Jan 26, 2010 12:51 am
hi guys
will a lwb vit tank fit into my swb sierra?
if so whats required?
drawbacks if any?
cheers andrew
Post Posted: Tue Jan 26, 2010 1:03 am
NO.. LWB vit tank is way to big... You want a SWB vit tank..
LWB vit uses V6 chassis which is wider than SWB 4 cyl chassis..
AFAIK the SWB vit tank fits pretty easily with just mount relocation. Better if you have a body lift.
See Taffs build thread or PM him as he's done it.
Post Posted: Tue Jan 26, 2010 1:13 am
SWB fits good but you will need a bodylift.
LWB vit tank
SWB vit tank
Sierra tank
The pump
SWB vit tank under there.
clearance to driver side shackle
Front left stock mount lines up with some bashing, had to make a mount for the other side.
If i did it again i would mount it hard up against the PS chassis rail to make the fuel filler 100000x easier.
Post Posted: Tue Jan 26, 2010 1:15 am
it will fit, but will require all new crossmembers, mounts etc. lwb estate v6 and 4 banger have the same rear chassis, only a different front section.
Post Posted: Tue Jan 26, 2010 3:36 am
doesnt pjzook run one in his swb??
thought i read somewhere he had the headaches making it fit.
appsie
Users browsing this forum: No registered users and 332 guests
