It is currently Sat Oct 24, 2026 8:06 pm
Vehicle: suzuki sierra coily
Post Posted: Thu Feb 25, 2010 3:25 pm
http://www.wheelersoffroad.com/wheels.htm
i just got a narrow track drover high roof. i was considering these rims to widden it up. wats ya thoughts. have just done 2" shackel and fitted 4" over sized shocks. but befor i do anything else i want to make it more stabble.. tyres are next.. whats ya thoughts??
the drover in the pic is before shot.. :twisted:
Post Posted: Thu Feb 25, 2010 5:15 pm
will be more stable......until the wheel bearings fall out! wheels like this also place a heap of leverage on king pins.
Post Posted: Thu Feb 25, 2010 5:26 pm
hell yeh do it, ya bearings will live
[img]http://www.nbs4x4club.com/forum/files/thumbs/
Post Posted: Thu Feb 25, 2010 5:32 pm
What are they worth? Maybe cheaper to fit WT diffs
Post Posted: Thu Feb 25, 2010 6:08 pm
Chances are your bearings will fail due to the seal getting chewed out in mud and dirt well before the extra load of those rims get to them.
Go for it.
weaves
Post Posted: Thu Feb 25, 2010 6:09 pm
You got that tin top from Cooroy hey... Nice clean car that one...
Wheels with big(ger than stock) offset will reduce wheelbearing and kingping bearing life but they are cheap enough to replace a bit more often.
I say save your wheel money and put WT diffs under it instead. You will eventually want bigger tyres and you'll need the spring clearance...
Go WT diffs.
Post Posted: Thu Feb 25, 2010 7:43 pm
i just put WT diffs on my NT, best thing i ever did!
Post Posted: Thu Feb 25, 2010 11:25 pm
ive got those rims on f100 offset they look awsome i love them but go the wt diffs
Post Posted: Fri Feb 26, 2010 1:21 pm
i can get them sent to me door for aprox $500 AUD. cheap set of mags.. i been ringing around for a new set of sunnies with neg 20 offset but they rare.. them suckers from states are near neg 50mm
i looking for W/T diffs, but i got a set of hilux diffs in top nick sitting there. would love tp do some cutting and shutting. i just picked up a g16b as well. so as soon as me sheds finished the work will begin..
(want33) yeah i got it from cooroy.
Post Posted: Fri Feb 26, 2010 1:45 pm
ill sell you a set of WT diffs! will be cheaper than $500. I thought you need a bundera rear diff because the pumpkin is off-center?
Post Posted: Fri Feb 26, 2010 2:02 pm
ill look into it.. Wat condition they in?? Locked?
Post Posted: Fri Feb 26, 2010 3:28 pm
great condition, have spoa perches if you need them otherwise cut em off. Ill check to see if they are locked tonight.
Post Posted: Fri Feb 26, 2010 3:31 pm
that be great. i just ordered 4 black neg 23mm 15/8 rims for me car. so she'll be as stable as with wide tracks in it..
Post Posted: Fri Feb 26, 2010 4:05 pm
The main advantage of WT axles isnt the width. Its the extra bonuses you get from that width.
ie: cromo CVS and more steering lock without scrubbing on springs.
Post Posted: Fri Feb 26, 2010 5:17 pm
wat ya mean taff? i trying to get more stability out of a wider wheel base? it just looks awkward with a high top. looks like it wants to lay over all the time. my wife works for Bundy motor group. i trying to get jeep flares to hide it all...
Post Posted: Fri Feb 26, 2010 5:43 pm
With WT axles the knuckle is further away from the spring.
They only make cromo CVs for WT axles.
Thats pretty much what i mean :?
Post Posted: Fri Feb 26, 2010 6:16 pm
For future reference wheelbase is the length between both axles. "Wheel track", is the width of the wheels as such.
Clearance Hole Technology :P
Vehicle: Clown Car..
Post Posted: Fri Feb 26, 2010 6:26 pm
To add to what Highway said above..
think of the model vairents we(as sierra owners) use..
LENGTH=SWBase vs LWBase
WIDTH=NTrack vs WTrack
HEIGHT= unmentioned vs Hightop :lol:
Post Posted: Fri Feb 26, 2010 7:59 pm
my mistake. i work on cars every day. you'd think i would of picked up on wat i sayed.. anyway. thats wat im out to achive, cause at the moment the drover is taller then it is wide..
Users browsing this forum: Google [Bot] and 65 guests
