It is currently Sat Oct 24, 2026 8:57 pm
Vehicle: G16b Sj80, Version 6 GC8 STi
Post Posted: Fri Mar 26, 2010 2:14 am
Okay so my stock alternator was sad for a few years, eventually it died and so I installed my falcon alternator last weekend... Driven about a dozen 10k trips since then, and now my battery is charged (it was totally flat from not bieng driven for a month) it's now putting over 17 volts into the battery.. It's all really hott and it blew like 3 if the caps off the top of the battery..
Dodgy alternator maybe...?
Subi + Suzi = Best of both worlds!
Post Posted: Fri Mar 26, 2010 2:19 am
voltage regulator is not working.
Vehicle: 1995 SWB Sierra TinTop
Post Posted: Fri Mar 26, 2010 2:33 am
hey man what kind of falcon is it out of as im looking for 1 so i can put a bigger battery in for a winch
95 Sierra SJ70 TinTop
Post Posted: Fri Mar 26, 2010 2:36 am
EL's and EF's have them. you need a mitsi alternator not the bosch
Vehicle: lj81 stockman
Post Posted: Fri Mar 26, 2010 2:37 am
yep reg is gone
the wobble rocks
Post Posted: Fri Mar 26, 2010 11:35 am
when your alt is reading 17 volts, what is the sense wire on the alt reading?
if like all sierras its a bit of a dodgy wire and it reads low it will make the battery overcharge, best to run a wire direct from the battery via a relay
Post Posted: Fri Mar 26, 2010 12:20 pm
It was 17 volts at the battery. I'm not sure about anywhere else. Will check when I get back from school.. And yeah it's a mitsubishi one... Is a regulator fixable or should I just go to wreckers and get completly different one?
Post Posted: Fri Mar 26, 2010 1:04 pm
Reg should be fixable, take it to an autolec. Should be a reasonabley cheap fix also
Post Posted: Fri Mar 26, 2010 2:09 pm
nah they arent cheap cause its soldered to teh diodes which also die and takes forever to get to, not like a bosch that just screws in the side
either that or the sparky that looked at mine is useless :wink:
Users browsing this forum: No registered users and 229 guests
