It is currently Sat Oct 24, 2026 11:53 pm
Post Posted: Sun Apr 18, 2010 7:50 pm
ok i am very soon rebuilding nearly all of my drive line adding gears etc, and am going to replace the clutch whilst i am at it!
is it worth it to replace it with a heavy duty one?
since i am already running more power than the standard one is designed for i was looking at this
http://www.lowrangeoffroad.com/index.ph ... h-kit.html
its about 120aud more than than a standard clutch!
Post Posted: Sun Apr 18, 2010 7:53 pm
oh btw i am doing a HUGE order from lowrange to start with so not ordering it from the states for no reason!
Vehicle: Jeep
Post Posted: Sun Apr 18, 2010 8:32 pm
I was going to put a HD clutch into my old 89 Vit, but Suzistore said only do it if you really need it, as the HD clutch has a tendency to stick, and not let go when hot... but i guess it depends on make... :wink: :lol:
Post Posted: Sun Apr 18, 2010 9:10 pm
Sounds quality.............
Post Posted: Sun Apr 18, 2010 9:14 pm
if you go HD get a few spare cables. :wink:
Vehicle: 1995 Sierra 1.3
Post Posted: Sun Apr 18, 2010 9:29 pm
I would imagine if you're getting gearing, a HD clutch wouldn't be a necessity.
Post Posted: Sun Apr 18, 2010 11:17 pm
my thought is a standard clutch is built for the single cam carbi 1.3, where i am already running the gti motor so 2/3's more power again!
yeah i am going gearing aswell, basicly this is my order atm!
i just want to do everything in one hit!
Vehicle: Sierra
Post Posted: Sun Apr 18, 2010 11:47 pm
can't help with the clutch but you might get hit with some taxes ordering all that in one hit.
Post Posted: Sun Apr 18, 2010 11:49 pm
Hi,
I bought a custom Clutch kit from NPC (Nick's performance Clutches) in Brisbane and it is awesome Exedy Clutch plate and his custom pressure plate that has huge clamping pressure but a really light pedal making it tops to drive, also got the Flywheel machined a spigot bearing as well as a throw out bearing all for $300 cash.
Also only my opinion but I don't think Sierra's need the coupler type Lockrite they work good as with the Std side gears installed.
Cheers David
Zuki
Suzuki Sierra 1990 Hardtop
Now just drive i
Post Posted: Sun Apr 18, 2010 11:52 pm
yeah mika i dont know how much before we get a tax but there is about 1k more to be added (joint order with a mate building his suzuki) we will see!
ah fair enough with the clutch i might scrach that off the list and put a exedy pink bits on it!
i thought the coupler was stonger? if not i will just get the one without! all cheeper for me :)
Vehicle: SJ50 hardtop!
Post Posted: Sun Apr 18, 2010 11:54 pm
Anything over $1000 bucks and your looking at paying an extra 15%
NT SJ50
Post Posted: Sun Apr 18, 2010 11:58 pm
If you talk to Sean at Low Range he might break it up and send it in sub $900 lots this way you avoid the Stamp duty and GST and Import Tax just a thought.
When we order we try and make order for around $900 and it goes through OK.
Also the Pink bits Exedy is a good clutch but is really heavy on the pedal.
David
Zuki
Now just drive i
wow.... is that each lot or order?
might see if i can do a few diffrent orders but sent at once... might be wishfull thinking though!
Post Posted: Mon Apr 19, 2010 12:00 am
thanks zuki it wont be orderd for around 4 weeks or so! but i will give him a call sean is the guy to speek to?
Post Posted: Mon Apr 19, 2010 12:02 am
Be wary of that as they do keep eye on broken up orders and then questions do get asked. but if there is a couple of days or so between then it works out ok.
David
Zuki
Now just drive i
Post Posted: Mon Apr 19, 2010 12:04 am
Yep Sean, he and wife / partner own/run Low Range and they are top people to deal with hey.
David
Zuki
Now just drive i
Post Posted: Mon Apr 19, 2010 12:06 am
David
ok sweet postage will be the killer i am thinking!
is it true to call them and they give u a much better quote on postage?
haveing never bought anything like this from the states its a big thing!
Post Posted: Mon Apr 19, 2010 12:08 am
when I order I email him and get quotes then he tells me to place the order and he catches it and modifies it to reflect his quote.
David
Zuki
Now just drive i
Post Posted: Mon Apr 19, 2010 12:13 am
thanks very much mate i will send him a email a bit closer to the day!
Post Posted: Mon Apr 19, 2010 12:16 am
you really shouldnt need a HD clutch once you have gears as the stress on the cluch will be greatly reduced by the gears.
mines still got the original shitter and she has 180,000km
Post Posted: Mon Apr 19, 2010 12:18 am
yeah thanks mate! it needs replacing so i guess i will just decide when it comes to the time! and what is avalable! i am just a tad worried with the extra power
Users browsing this forum: Google [Bot] and 205 guests
