It is currently Sun Oct 25, 2026 7:30 am
Post Posted: Wed May 12, 2010 5:41 am
I am just in the process of putting a new clutch in my sj413 g13a 1.3< how to you disconnect and remove the starter??
Vehicle: '92 Sierra
Post Posted: Wed May 12, 2010 6:00 am
Undo the nut holding on the heavy gauge wire. Pull the others off. Undo one bolt top and one bolt bottom (if I remember right they are 12mm) and it should come out. I always struggle with that top bolt.
Post Posted: Wed May 12, 2010 6:03 am
from memory there's a nut/bolt at the bottom and a bolt at the top, where the transmission meets the starter, two wires to disconnect and it should just pull straight back (towards the front of the car)
small hands/arms will help
Post Posted: Wed May 12, 2010 6:19 am
disconnect your battery first or you may end up with quite a few sparks if the positive lead flaps around too much
Post Posted: Wed May 12, 2010 6:33 am
You dont even need to remove starter to do a clutch, just disconnect the earth terminal on battery, undo the two bolts holding starter motor on, then remove gearbox, easy.
Vehicle: '85 Sierra LWB Ute, Lkd 33's
Post Posted: Wed May 12, 2010 8:19 am
get a set of ratchet spanners 8, 10 and 12mm will make life 20x easier, especially for things like taking the starter motor out
Post Posted: Wed May 12, 2010 8:48 am
I'm with you on that PJ.
Post Posted: Wed May 12, 2010 9:11 am
hammer gets them off every time
Users browsing this forum: Google [Bot] and 168 guests
