| Author |
Message |
andy1517
Joined: Mon May 05, 2008 11:30 pm Posts: 104 Location: Brighton, Victoria
 Posted: Thu May 27, 2010 9:19 am |
Guys,
just purchased a arb bar for my swb 94 sierra.
I have a 2" body lift, and the bar has been modded for a 2" lift.
Does anyone have any pics of the mounting points?
Thanks
steak_knife
 Posted: Thu May 27, 2010 9:25 am |
Normally to the chassis rail's but depends how it's been modded.
Post a pick of the back of the bar..
89_tintop
Joined: Fri Aug 07, 2009 11:30 pm Posts: 3159 Location: gold coast
hey mate i used the top hole in the chassis for the bottom mount in the bar and the welded on a bracket to the top of the chassis for the top hole.
cant take pics of it as it is a tight squeeze and doesnt really make sense
Gwagensteve
Joined: Thu Feb 26, 2009 10:30 pm Posts: 13013 Location: Melbourne
 Posted: Thu May 27, 2010 9:43 am |
Did you buy Dank's bar andy? Why not ask him?
andy1517
 Posted: Thu May 27, 2010 9:47 am |
I know he used standard mounts. I was wondering if anyone had pics of this?
I have to pull my bar off first to have a look at what condition my mounts are in.
But before i go hacking into my bar, i want to make sure i don't hack off the actual mounts. make sense??
steak_knife
 Posted: Thu May 27, 2010 9:57 am |
andy1517 wrote: I know he used standard mounts. I was wondering if anyone had pics of this? I have to pull my bar off first to have a look at what condition my mounts are in. But before i go hacking into my bar, i want to make sure i don't hack off the actual mounts. make sense??
Hack it off? What do you have on the front now??
bron5on
Joined: Thu Apr 02, 2009 10:30 pm Posts: 285 Location: Hobart
Vehicle: SJ80
 Posted: Thu May 27, 2010 11:54 pm |
If the bar has been modded instead of the mounts it sounds like all you need to do is unbolt your bar and bolt the new one on. Should be no hacking involved. Easiest way to find out is to get on the end of a spanner. Shouldn't take long to take your bar off.
bagnkat
Joined: Sun Aug 16, 2009 11:30 pm Posts: 346 Location: Port Stephens.
Vehicle: SJ80
 Posted: Fri May 28, 2010 2:54 am |
steknig wrote: Post a pick of the back of the bar..
x 2, I'd also like to see how he modded it for the lift
Crunched
Joined: Fri Mar 05, 2010 10:30 pm Posts: 684 Location: Sth Bris
Vehicle: Sierra Utey!
 Posted: Fri May 28, 2010 3:07 am |
I'd also think about making some sort of mount that goes from the bullbar to the outriggers on the chassis (or what is left of them if they have been cut off, like most sierras). I think the standard ARB bar mounts use the outriggers as well as the chassis, but most people cut these off when they shorten their outriggers.
I have no faith at all in using just the chassis rail mounts - 4 bolts about 3-4mm from the very end of the chassis rail... Maybe just ok for slow winching, but if someone tries to snatch you out of a deep mud hole...stand clear...
_________________ My ute..
joeblow
Joined: Sat May 10, 2008 11:30 pm Posts: 3273 Location: melbourne
 Posted: Fri May 28, 2010 3:15 am |
Crunched wrote: but if someone tries to snatch you out of a deep mud hole...stand clear...
ALLWAYS use a chassis point and never the bar, even on a standard setup. they are designed for winching and not the loads from snatching.
_________________ builder of custom road legal zooks......and stuff.
Crunched
 Posted: Fri May 28, 2010 3:16 am |
joeblow wrote: Crunched wrote: but if someone tries to snatch you out of a deep mud hole...stand clear... ALLWAYS use a chassis point and never the bar, even on a standard setup. they are designed for winching and not the loads from snatching.
Most definitely Joe, but ever been in a situation where someone backs up, hooks up, and goes? I have...
