It is currently Tue Oct 27, 2026 10:45 am
Post new topic Reply to topic  [ 46 posts ]  Go to page Previous  1, 2
Post Posted: Fri Dec 18, 2009 3:51 pm
Hey guys just swapping my old drover carby over to a secondhand one... found this lil pipe which the drover one doesnt have (see pics below)
Any ideas what it is for what I should connect it to?
[quote="zookieboi"]has anyone really been far even
Post Posted: Fri Dec 18, 2009 3:53 pm
two pipes on drover one... this is on the engine side of the carb...
Post Posted: Fri Dec 18, 2009 4:43 pm
The two on one side goes to the dizzy and charcoal canister. The other side goes to a solenoid towards the front of the motor.
I've got pics I'll try and load heaps easier to follow. Won't be long.
SS
Post Posted: Fri Dec 18, 2009 4:54 pm
Two going to #19 to dizzy and #27 to canister
The other one #18 going forwards along rocker cover.
The forward one goes here below the thermosat .
Hope this helps.
SS
Post Posted: Fri Dec 18, 2009 5:00 pm
yeah it does cheers DMAC! my only prob now is my old carby only had the one going back to the dizzy... so these carbs probably arent compatable?
Post Posted: Fri Dec 18, 2009 11:17 pm
Just block the second one off.
I assume (i may be wrong) your drover doesnt have a carbon canister and vents the fuel tank breather to atmosphere.
The second plug which runs to the carbon canister is solely for emission purposes.
Post Posted: Sat Dec 19, 2009 12:11 am
sweet nope still got the canister but its connected to something else i forget where...
Post Posted: Tue Feb 16, 2010 2:36 pm
Rockhopper wrote:
but does the car behave any differantly when you switch the headlights on?
Interestingly I have this happening with a G16A Vitara - just had the carby rebuilt and noticed it last night that when the headlights are on the idle is all over the place. What turned out to be the fix?
Vehicle: I drive your mum
Post Posted: Tue Feb 16, 2010 4:43 pm
There is a small vacuum pot at the front of the carby. When the headlights or other electrical load is applied vacuum is applied to this pot. This pulls the idle up throttle stop in, raising the idle. Get a mate to switch the headlights on as its running. Watch at the front of the carby and you should see the little lever pull in. If it idles really high, adjust the stop down and vice versa. ~800rpm is correct for electrical load on, and ~700rpm for no load. (from memory, im sure if im wrong someone will point it out).
Layto....
Post Posted: Wed Feb 17, 2010 1:53 am
Layto....
Thanks for the info.
Vehicle: 2012 Jimny, Locked both ends
Post Posted: Sun Jun 06, 2010 10:18 am
hi all, digging into a bit of an old topic, But got a problem related to the tuning of carb,
car is running realllly rich thick black smoke puffing out of the old girl,
What adjustment should i be making, or more importantly wich screws should i be adjusting and what effect will each have. thanks alot
Jordan
Post Posted: Sun Jun 06, 2010 11:18 am
check to see the choke flap opens up when the car reaches operating temp
Post Posted: Sun Jun 06, 2010 11:24 am
when u say open do u mean wide open, or do u mean just a gap?
Post Posted: Sun Jun 06, 2010 11:31 am
When engine is at normal op temp, the choke should be wide open (straight up and down)
Post Posted: Sun Jun 06, 2010 11:39 am
think that may be what the issue is as it is only got about 4mm gap. will have to check it out tomorow
Post Posted: Sun Jun 06, 2010 12:06 pm
Oh yeah sorry guys, If i need to get it to open up more, whats the best way to adjust it.
thanks again
Jordan
Users browsing this forum: No registered users and 162 guests
