It is currently Thu Oct 29, 2026 10:44 am
Post new topic Reply to topic  [ 47 posts ]  Go to page Previous  1, 2
Post Posted: Tue Dec 29, 2009 12:00 am
sheps right on the money with this one. that would be a first :finger:
there's no point buying a snatch strap if its much over 4000kg as the strech part of the strap is not employed, you may as well just use a tow strap as your getting the same effect.
all the data on straps suggest that the strapp should be rated 2 to 2.5 times heavier than the weight of the vehicle being recovered or recovering.
I use a 6000lbs shitter i got off fleabay its perfect for suzukis and cost $ 40.
Post Posted: Sat Mar 20, 2010 3:50 am
i use t-max 6000lb straps and t-max 4000kg 20mtr extension straps, i have 4 of each and
they work great. i don't bother trying to recover anything bigger then a Suzuki any more as they don't deserve it.
the snatch straps cost me $35 and the extension straps cost $40
shep where did you get the 6000lb snatch strap from?
lowest rated t-max snatch i can find is this one
im looking at getting this just straps 4.4t RLL one for $54.45?
anyone else know where to get snatch straps suited to a sierras GVM?
Think before you post to make AZ a better place :)
Post Posted: Sun Mar 21, 2010 12:06 am
just straps are getting harder to get. BCF have stopped stocking them now
Vehicle: SJ50 hardtop!
Post Posted: Sun Mar 21, 2010 1:24 am
Repco's got the maxi trac recovery kit on sale now for 79$
http://catalogues.repco.com.au/portal/o ... geview=two
NT SJ50
Post Posted: Mon Mar 22, 2010 5:04 pm
thats still way too high of a rating....8,000kg=17,600lb! well over 2-3x a sierras GVM which is from my understanding the ideal rating for a snatch strap
Post Posted: Mon Mar 22, 2010 5:18 pm
18mm 8 strand nylon rope, elastic as a rubber band and strong as.
I have about 140 foot.
. When I pull (often)full sized tojos n pootrols out of the sand, down to their diffs, I flake the line on the beach, and as I see it starting to come straight, I floor it in first, the line will come up, stretch about a 3rd of its length, suziblu will feel a slowing down, and out pops the bogged piece of crap.
I have tried snatch straps, and the suk big time, I hate the feeling of near throwing myself out the front window as the strap pulls tight, and suzi does not have enuf weight to (inertia) to stretch it.
Post Posted: Mon Mar 22, 2010 6:12 pm
i got the straps from a mob called independent motor mart, 2 or 3 years ago.
IMM have since been bought by REPCO so they may stock them.
Post Posted: Mon Mar 22, 2010 6:42 pm
another vote for the 6000 kg just straps. i have one and have used it on sierras, hilux, wrangler, pathfinder with a trailer hooked up, pajerio and a range rover. most of the time its the sierra pulling the other car out. its a nice soft snatch with plenty of strech. had it for 2 years now and it looks like new still.
if your getting a big bang the strap is to big for your car. if your strap make you feel like the sierra is to light to pull it out. the strap doesn't have enought strech in it.
Post Posted: Mon Mar 22, 2010 9:47 pm
newcaslte BCF had a few in stock when i was there this arvo
I use a 9 tonne ARB strap, mainly because i only usually go out with bigger vehicles, one of the guys with me has a 18 tonner which will never ever be used on mine.
Vehicle: LWB Sierra & XL7
Post Posted: Mon Mar 22, 2010 11:23 pm
I bought my TOW2GO straps from Super Cheap, not only because I worked there, but I got them for $20 each. They were discontinued to may way for the Ridge Ryder gear and they've paid themselves off.
After telling someone how much I bought them for, I was told I'm dicing with death. The straps have an Aust. approved capacity rating, Date of manufacture which was newer than his ARB strap, Umm so If I buy a $100 strap does that mean I'm smarter?
While were on the topic, what's the lifespan of a strap?
I know it depends on the amount of use it get's but do you just chuck it out when it's damaged or after X amount of years.
'92 Vitara & Camper trailer
Post Posted: Mon Mar 22, 2010 11:47 pm
I bought my first new strap in 15 years today. Happened to be on special for $37 at Stupid Cheap so I grabbed one. Old one was still going strong but was too heavy so will be interesting when I get to test it.
I once used my old strap and my Sierra to free a troopy with a large trailer that was down to the chassis rails on the teewah beach cutting. It took about 9 snatches but I got him out.
Vehicle: Sold zuk got a Bt50
Post Posted: Fri Sep 03, 2010 12:40 am
Bringing up an old thread again but what rating snatch strap would you suggest for a GV i know people have told me before but i cant remember what they said
bt50 now but still love the zooks
Vehicle: 75 Cruiser
Post Posted: Fri Sep 03, 2010 12:58 am
Depends, are you pulling out Patrols or Suzukis ? :D
Post Posted: Fri Sep 03, 2010 12:59 am
It will be to pull me out if they don't have a strap I'm not pulling them out with my strap
Post Posted: Fri Sep 03, 2010 1:02 am
6000 pounder should be fine
Post Posted: Fri Sep 03, 2010 1:03 am
how much does it weigh?
like in a previous post you only need 2.5 times the weight of your car.
so if it weights 1500kg you only need 3750kg snatchy. The most common ones these days are 9000kg, thats what i use, but i have never been so stuck that huge, repetitive snatches where required to get me unstuck.
Get one of the lowest rated ones you can find - 6000kg would be a great one
Vehicle: 75 Cruiser
Post Posted: Fri Sep 03, 2010 1:08 am
yer i usually use a 6000pound one and work well and nice and smooth. I also have a big nasty 8 or 10,000 i think it is and it's pretty rough :lol:
Users browsing this forum: Google [Bot] and 310 guests
