It is currently Tue Oct 20, 2026 10:08 am
Post Posted: Tue Apr 01, 2008 1:16 pm
Has any one put 6" speakers in the front of there zook? Where abouts did you put them?
I have an idea of taking the map pockets off and putting them there on a spacer, but not sure what the door trim will look like under the map pockets. It might look real crap, and i dont really feel like making up fiber glass door pods...lol
Post Posted: Tue Apr 01, 2008 1:25 pm
I have an 8 and a 5 in each door, plenty of room but no depth
Post Posted: Tue Apr 01, 2008 1:27 pm
Did you remove your map pocket? Or are they on the flat section between that and the handle? I was going to mount them there but i was not sure if there was going to be enough room for my knee...
Have you got a pic i can see?
Cheers David
Post Posted: Tue Apr 01, 2008 2:36 pm
I have a crap version with no map pockets
there is a pic in my members thread somewhere
Post Posted: Tue Apr 01, 2008 4:04 pm
Found them, cheers
Post Posted: Wed Apr 02, 2008 7:30 pm
I use Stock Locations with a Well Built 4 inch 2-way, then a Set of 6 inch in custom side panels and a 10 inch Sub to cover everything else... Sounds Sweet as and best of all.. I can re- install all the stock gear with no need to buy replacements when I sell it...
Vehicle: Suzuki Grand Vitara
Post Posted: Fri Apr 04, 2008 2:56 am
The poverty pack Vitara like I have only has the speakers in the dash.
I have been thinking of upgrading as well, but not a fan of door speakers unless they are flush mounted.
You end up kicking them alot if not in the right place.
Not that you get much option in the Vit, if you put them in the back and are loaded up with gear then it will block out the sound.
Might look at some replacement speakers for the dash but I don’t know if you can get good sound out of speakers that size.
Post Posted: Fri Apr 04, 2008 12:14 pm
Yeah...
You can get Decent sound out of a 4 incher, alot of quality, just not alot of Bass..
I Use Pioneer 4 inch 2-ways in the dash and they are Very clear..
JBL Have 4 inches that sound good too..
As For Bass, try and track down a Clarion SVR303 Under seat Sub..
It will fit just about anywhere in a Vitara and will give you some low end without chewing up alot of Space..
Post Posted: Fri Apr 04, 2008 4:19 pm
Water lives under my seat, not subs and amps....lol
Have you amplified your front stage?
Post Posted: Sat Apr 05, 2008 2:49 am
No need to amp my fronts.. there like 2 feet away.. and my Pioneer deck does a good job of providing a clean signal..
Users browsing this forum: No registered users and 243 guests
