It is currently Tue Nov 03, 2026 10:05 am
Post Posted: Sat Jan 08, 2011 7:33 am
are the roughly the same width from hub to hub on the front.
thinking about getting 1 and coiling it for the front of the zook,
cause i think u can do diff gears and chromoly axles and cvs then
Post Posted: Sat Jan 08, 2011 7:54 am
8O
steak_knife wrote:
8O
Post Posted: Sat Jan 08, 2011 8:00 am
should have just bought a sierra instead of the made of glass jimny :wink:
joeblow will know
Post Posted: Sat Jan 08, 2011 8:04 am
No. Not even close. And you can't get chromos for NT either.
A WT will be the closest and best for chromos and width.
NT = 49"
WT = 52"
Jimny = ?
This is going to be one of them threads that runs away, people get called names, people cry, people say things need to be moderated
Jimny is wider than a WT sierra, hence why joeblow is using axle bits to make his wide front diff
youll also have steering bits in the way
Post Posted: Sat Jan 08, 2011 8:07 am
steak_knife wrote:
8O
Where do I start??
No cromo's for n/t
n/t different size to Jim ( roughly)
& what ajsr said..
Post Posted: Sat Jan 08, 2011 11:47 am
jimnys are difference, or i could just scrap the idea of a front locker and just brace mine so i can drive a bit harder
Post Posted: Sat Jan 08, 2011 11:50 am
i'm pretty sure ARB do front & rear lockers if that's what your after?
Post Posted: Sat Jan 08, 2011 11:59 am
If you have cash to burn, PM joeblow and get one of his custom diffs.
Post Posted: Sat Jan 08, 2011 12:30 pm
you worried about bending the front diff or breaking cv's?
Post Posted: Sat Jan 08, 2011 1:17 pm
bending it and bracking cvs once i lock it.
if i dnt lock it i will be able to drive harder, hence the diff bracing, if i lock it ill still brace it but ill just want stronger cvs and axles.
dodgy brothers mechanical
Post Posted: Sat Jan 08, 2011 8:18 pm
U can get cromo for jimny or Joe can make them
Post Posted: Sun Jan 09, 2011 1:32 am
Might have some WT housings up for sale in a month or so :roll:
Post Posted: Sun Jan 09, 2011 2:08 am
jimny looks to be about 53" going by this http://www.ebroadcast.com.au/ecars/Suzuki/Jimny.html site
Vehicle: zook
Post Posted: Sun Jan 09, 2011 11:20 pm
NT = 49"
WT = 52"
Jimny = ?
jimny front 53.3
Rear 53.7
from owners manual.
Post Posted: Mon Jan 10, 2011 8:49 am
yea cheers, i think ill stick with the jimny diff, just brace it and drive a bit harder if i need to.
cheers for your feed back guys
Post Posted: Mon Jan 10, 2011 9:40 am
you shouldnt break CVs or axles if you drive it right... you're only running 31s so it should be ok.
dont drive it like this: http://www.youtube.com/watch?v=WMXT7LUAl6A
lol
Post Posted: Mon Jan 10, 2011 10:04 am
lol
looks like my driving :P jks well maby a a little
Post Posted: Thu Jan 13, 2011 10:05 am
D40 Land Patrol ones slot straight in :wink:
Post Posted: Thu Jan 13, 2011 10:24 am
do they
Post Posted: Thu Jan 13, 2011 10:26 am
smiffkid wrote:
do they
Only when fitted upside down.
Post Posted: Thu Jan 13, 2011 11:10 am
smiffkid wrote:
do they
is that to correct the circle spin ratio of the suzuki diffs?
Post Posted: Thu Jan 13, 2011 11:12 am
smiffkid wrote:
do they
Yes. They are reverse cut hypoid ring and pinion, so you need to flip the diff. This puts the castor out, so you just fit some castor wedges to get it back to stock settings.
Post Posted: Thu Jan 13, 2011 11:19 am
smiffkid wrote:
do they
don't they become worm drive gears once flipped?
Post Posted: Thu Jan 13, 2011 11:24 am
smiffkid wrote:
do they
No, because they are helical cut gears.
Post Posted: Thu Jan 13, 2011 11:28 am
smiffkid wrote:
do they
:rofl: see how easy it is smiffkid.... misinformation is like a plague. :thefinger:
Post Posted: Thu Jan 13, 2011 11:34 am
haha
smiffkid wrote:
do they
:lol: :lol:
Users browsing this forum: No registered users and 87 guests
