It is currently Tue Nov 03, 2026 11:45 am
Vehicle: Work van
Post Posted: Thu Jan 27, 2011 4:44 am
I searched but didn't find anything, the transfer arms I got from a wrecker for my rockring, the log arm has big holes where the rubber mounts bolt up to instead of the 3/8? Hole and smaller locating hole, would it be safe to weld a plate in and drill the holes that I need?
Swb softie spoa cromo front -50 beadlocks 6.5s :D
Post Posted: Thu Jan 27, 2011 7:47 am
Yes, while you have the glue gun out brace the rest of it to..
Vehicle: Work van
Post Posted: Thu Jan 27, 2011 8:33 am
Yea got some dimples dies that should be here next week :) and roctoy ring is going on at the same time
Vehicle: Daisy
Post Posted: Thu Jan 27, 2011 8:51 am
shit that reminds me to find a place to get a roctoy from!
Dimple dies as in for making sheets stronger? (thanks google) is that for your plate you're planning to weld over the holes?
Vehicle: Work van
Post Posted: Thu Jan 27, 2011 8:57 am
Yea dies to make the sheet stronger, using them because they are super cool and so I can brace my ring to the arms with 3mm plate and still keep it strong, the bigger holes will just be plated glued then re drilled with the right holes
Users browsing this forum: No registered users and 207 guests
