It is currently Tue Nov 03, 2026 10:02 am
Post Posted: Sun Jan 30, 2011 2:44 am
Has anybody has the problem of there webber getting rich as shit on a bumpy track.
Mine. Is doing it at the moment I think it must be the fuel level splashing around to high on the bowl.
Any thoughts?
Post Posted: Sun Jan 30, 2011 2:55 am
go faster so the bumps smooth out and you suck in the excess fuel? =P
Post Posted: Sun Jan 30, 2011 3:03 am
Hahah I wish it was that easy
Post Posted: Sun Jan 30, 2011 5:38 am
Post pic's... :lol:
as I said the other night, webber's blow...
Post Posted: Sun Jan 30, 2011 7:41 am
Haha I think I am going to have to put some sort of splash plate the the bowl.
As for the pics umm, my cameras broken ;-p
Post Posted: Sun Jan 30, 2011 7:49 am
Yr's ago I had a flooding issue with a webber & it ended up being a "breather" type gap in the housing of the bowl, just made the gap not there any more & gave it a new breather, but in your case a new breather may be an issue.
Post Posted: Sun Jan 30, 2011 8:25 am
check your float level.
Post Posted: Sun Jan 30, 2011 9:15 am
Float level is fine:( I wish it was that easy)
Post Posted: Sun Jan 30, 2011 9:17 am
I think I am going to lower my fuel pressure abit and mabey lower the float a wee bit
Post Posted: Sun Jan 30, 2011 9:24 am
Take a pic of the top of the bowl with the lid off, I may be able to see if it's the model with the stupid "breather" or not.
It's just a recess that let's petrol into the throat..
Post Posted: Sun Jan 30, 2011 9:25 am
:lol: You can send it to my phone if you like.. :lol:
Post Posted: Sun Jan 30, 2011 9:31 am
Hahah yea it is the model that you can see the fuel in the bowl( the hole is about 8mmx 25mm from memory)
Post Posted: Sun Jan 30, 2011 9:41 am
can you make a tube or the like's to raise that up??
It will still pressurizer, but you ay not get the splash affect your getting now..
Post Posted: Sun Jan 30, 2011 2:56 pm
Here we will that breather vent that with jb-quick, or epoxy, then drill a small like 1/8"hole in it.
Take some 1/8" clear fuel hose, and insert it in the hole. Leave about 2" of hose sticking out. Take that hose that is sticking straight out, and bend it in a "U" shape so it goes right back down to the carb throat.
You use loctite red to secure the hose in the hole you drilled through the epoxy.
Doing it this way the fuel has to come all the way up that hose, and back down to get into the main throat, and you still have a float bowl vent.
Pressure is critical with weber's. You should only have 1.5 to 2lbs of fuel pressure max when off road.
For the float you can lower it a bit, then add some drop to the needle valve. The extra drop in the needle valve fills the bowl quicker, and makes up for having a low float setting.
Hope that helps.
Steaky's right weber's are a rough one to use in a Sierra. I fought mine for a couple of years.
Post Posted: Mon Jan 31, 2011 6:10 am
Hope that helps.
That'll do it.. :P
Users browsing this forum: No registered users and 93 guests
