It is currently Wed Nov 04, 2026 6:04 am
Post Posted: Thu Feb 17, 2011 6:22 am
have done my vitara engine swap, but engine fowls bonnet my about an inch id say. so am looking at doing a 2" body lift, much to my distaste..
does anyone have any opinions on fit and quality v's cost for a kit?
and mabey some links to a sales page?
thanks.
Post Posted: Thu Feb 17, 2011 6:25 am
thanks.
the best that money can buy can be found right here. http://auszookers.com/index.php?name=Fo ... ic&t=15518
don't bother wasting any more mouse clicks... :wink:
Vehicle: 1995 SWB Sierra TinTop
Post Posted: Thu Feb 17, 2011 6:29 am
just put a 1inch spacer on your bonnet hinges, zookimonsta did that on his haha its also a good heat disapator thingy majig
95 Sierra SJ70 TinTop
Post Posted: Thu Feb 17, 2011 6:34 am
mm i would like to keep the outside looking as close to stock as possible body wise, the cops in this town are assholes.
looks like a just cruzin bl it is then. might get a transfer lift then too whyle im under there.
thanks for that atari. yess!!
Post Posted: Thu Feb 17, 2011 7:01 am
You may also be decapitited in a big head on too.
Post Posted: Thu Feb 17, 2011 8:27 am
don't be lazy. :roll: Make new engine mounts that lower your motor. I have fitted 2 G16B vit motors under a 1L bonnet with NO body lift. Sump clearance was fine in both cases. 8)
Post Posted: Thu Feb 17, 2011 9:00 am
i got a little bonet scoop on myne with no body lift it just closes
Post Posted: Thu Feb 17, 2011 9:09 am
this would've been nice to know earlier :oops:
Post Posted: Thu Feb 17, 2011 9:20 am
Search noob :finger:
http://auszookers.com/index.php?name=Forums&file=viewtopic&t=9787
Post Posted: Thu Feb 17, 2011 12:48 pm
ahh fuuuuu lol i forgot i had to fit a 1.3 sump :oops:
being a vitara motor, with no crank angle sensor on the sump, the 1.3 sump should fit with no welding needed ay? just the pick up modded?
any chance of having the motor sitting like that, but with engine mounts that bolt to the stock chassis mounts? (the two bolt plates ether side)
i suppose make a plate that bolts to the chassis, with the pick ups off it, and make the engine plates and bushes to suit..
back to the drawing board.. :(
Post Posted: Thu Feb 17, 2011 12:55 pm
If you do full RUF at the same time you can keep the vit sump.
And I'm not sure if you could mount the motor that low and not modify the rail mounts sorry.
I'll take some pics of my mounts tomorrow arvo. They use a fish plate on the rail, but use VL crummydore mounts onto the sierra engine block mounts. Its a smidge taller than the link above, but easily clears a 1.3L bonnet.
PS. How are your welding skills?
Post Posted: Thu Feb 17, 2011 12:57 pm
ok, if ur still on here in a minute, il go out and take some photos of what myne looks like and if its possible, give some advice? :oops:
be back in a sec.
Post Posted: Thu Feb 17, 2011 1:07 pm
heres how it sits at the moment, drivers side (1.3 mount) isnt bolted to the rail.
and my welding skills is ok, i made a car trailer that has done afew 800k round trips with no hassles. done with stick, and i have a cigweld proffesional series mig (175i)
that is where the bonnet sits on top of the plenum.
Post Posted: Fri Feb 18, 2011 9:20 am
I think mine is sitting lower.
I'll go down to the workshop and get some pics.
brb
Post Posted: Fri Feb 18, 2011 9:25 am
mine sits wayyy lower than that... the rubbers in the mount there are massive compared to mine.
Post Posted: Fri Feb 18, 2011 9:35 am
Here is mine with VL mounts. These mouns clear a 1.3L bonnet by 20 or 30mm with no BL. I have just used the sierra mount brackets between the Rubber mount and block, then welded a fish plate to the rail and made mounts to bridge the rest of the gap.
Drivers side mount.
Passengers side.
Post Posted: Fri Feb 18, 2011 9:39 am
you have the wrong oil filter
Post Posted: Fri Feb 18, 2011 9:41 am
Its bigger than the 'right' one :wink:
Post Posted: Fri Feb 18, 2011 9:42 am
Its made for a Toyota
Post Posted: Fri Feb 18, 2011 9:44 am
It filters my oil. I made it my bitch.
Vehicle: 96 coily Awesome sticker Rust
Post Posted: Fri Feb 18, 2011 9:46 am
Yeah my left one hangs lower than the right too
I have issues
What are you looking at
Post Posted: Fri Feb 18, 2011 9:48 am
Trust you to look. 8O :gross:
Post Posted: Fri Feb 18, 2011 9:49 am
the brackets that are bolted to your block are different to myne... are they the stock 1.3? or different again?
see, thats what i would like to avoid, is the cutting of the stock plates and welding on something like you have above. not that i dont trust my welds.
thats more or less the only way to do it?
by the way, my mounts are r31 skyline mounts. i assumed they would be the same?
do you reccomend me put the 1.3 sump on, or leave the 1.6 one? im so confused now.. :(
Post Posted: Fri Feb 18, 2011 9:53 am
Mate there are a million ways to fuck this cat.
What I usually do is get the motor sitting at the height you want it..... wedge some blocks of timber etc in to hold it there, then start putting the oieces of the puzzle together. You will have your own unique set of issues to tackle with keeping the chassis mounts.
All I can suggest is that you do this ^^^^^ and take some pics and post 'em up.
Pete
Post Posted: Fri Feb 18, 2011 9:55 am
NFI on the mounts. Pics?
Are you doing RUF? if yes, leave the sump. If no, then you may have to swap it.
Post Posted: Fri Feb 18, 2011 10:12 am
i will be doing a ruf, and a ful ruf, extending the chassis abit for the shackle hangers. still unsure of that springs im running in the rear. but eh.
the passenger side mount in the pics i put up are r31 mounts. they look identical to me. will start from scratch now.
will ether cut off the stock plates from the chassis and do as you have above, or make custom motor plates and make mounts from that.
and make up a gearbox mount for the vitara box aswell, so it sits a little lower than it does atm, as the shifter plate is hard against the tunnel. and so the jack shaft isnt on such a insane angle.
ether way will be back to the drawing board, and you have given me some good ideas, fatzook. thankyou.
will get in touch for a tank guard etc once its running.
thanks! will post pics as i work in my build thread thing.
Post Posted: Fri Feb 18, 2011 10:20 am
If you do full RUF, then leave the sump for now.
I flared my tunnel to suit the vit gearbox. Also made a shifter neck adaptor so as to keep the sierra shifter.
If you are making a new gearbox mount aswell, then this is the perfect opportunity to move the engine back and down. This will help slightly with COG, but give you better sump clearance with the 1.6 sump.
The mounts will only take you a few hours. Have a good think about all your options before you chop 'em off tho :D
Peter
Users browsing this forum: Google [Bot] and 173 guests
