It is currently Thu Nov 05, 2026 2:03 am
Post new topic Reply to topic  [ 39 posts ]  Go to page Previous  1, 2
Post Posted: Fri Dec 10, 2010 7:30 am
christover1 wrote:
f100 trailer hubs may only suit heavy duty axles, this was the case a while ago, and were more expensive because they were bigger than car size hubs.
Could be different now.
I bolted zook brake drums to a stock holden trailer hub..not easy to drill a trailer hub tho.
yeah you probably would only get them with slimline ford bearings not the cheaper holden LM type.
but the slimline are a better brearing anyway
Post Posted: Fri Dec 10, 2010 7:33 am
Post Posted: Fri Dec 10, 2010 7:36 am
^^^ that trailer is so cool, the perfect size. 8)
Post Posted: Fri Dec 10, 2010 7:43 am
nice to see someone with useful info :P
Post Posted: Tue Mar 08, 2011 8:12 am
I got a small trailer from the dump for $50, it's been someone's refit project for a while, but he's given it up.
It'ss got holden shit on it, I can get a mob here to order me F100 hubs, but I don,t understand about axles,I know there is square and round,anything else I need to know?
No swearing at me like the start of this thread,I got it for search.
bye
Post Posted: Tue Mar 08, 2011 8:25 am
Square and round only changes how you fit springs.
Square axles could be easier to get the springs bolted straight.
Round axles need a flat seat welded on to them.
Heavy duty hubs will only go on hd stub axles.
Light duty hubs only fit light duty stub axles.
Axle tube is thicker and heavier when heavy duty.
This is the limit of my understanding.
Post Posted: Thu Mar 10, 2011 8:04 am
I learn a little bit more everyday.
There is no heavy duty axle.The difference is in the bearings.The Holden{smaller ?]goes from thread to round . The Ford is stepped up from the thread.The Ford is reputed to be more robust.
F100/suzuki hubs can come in either @ $85.00'
The guy had two,so we went out to show me that the patern was right....
some -head had put 'cruiser studs in.
He could change them for me, and I will get them if that guy buys all these good tyres I've got.
Post Posted: Thu Mar 10, 2011 8:38 am
I have not tried this but was thinking about how else you coud achieve sierra stud patern, you could make a piece of 120 X 100 X 20mm thick plate machine a 80mm round female centreing flange, drill 4 holes in it, weld it to the end of a square section axle and bolt a front seirra hub on with a blanking plate where the FWH would normally bolt on. That way you use front sierra bearings and all easily replaced sierra bearings and parts. anyone see any probs with this idea ??
[/IMG]
Post Posted: Thu Mar 10, 2011 7:17 pm
Blanking plates like these
Users browsing this forum: No registered users and 273 guests
