It is currently Fri Nov 13, 2026 5:26 am
Post new topic Reply to topic  [ 37 posts ]  Go to page Previous  1, 2
Post Posted: Thu May 12, 2011 2:13 pm
dave91 wrote:
what is the crossmember? what's it do? hahah
2 things.
1.... It hold the back of the gearbox up, and
2.... It acts as a 'brace' between the left and the right chassis rails. :wink:
Post Posted: Thu May 12, 2011 2:29 pm
it is a piece of metal that goes from one frame rail to the other and supports the gearbox, as well as holding the transmission mount, and stiffening the frame rails laterally
Post Posted: Thu May 12, 2011 2:31 pm
There is an echo in here :lol:
Post Posted: Fri May 13, 2011 12:52 am
Jinx
Post Posted: Fri May 13, 2011 12:54 am
ok so what do you mean when you say that you cut it off/ cut it down so that it doesn't snag on anything?
Every problem can be solved with a Ratchet.
Vehicle: 2018 DMAX
Post Posted: Fri May 13, 2011 12:56 am
dave91, this gives you an idea where everything sits.. Basiclly get everything higher than the bottom of the chassis rail is what people try and do..
Post Posted: Fri May 13, 2011 1:10 am
skyman wrote:
You guys have an excellent recipe for a low COG , and very capable Sierra. It shows me that over half of the Zooks built here would do just as well with a low COG and 31's as they do on 33's, given the same terrain.
AZ style is catching on!!! :)
Users browsing this forum: Google [Bot] and 63 guests
