It is currently Sat Nov 07, 2026 10:24 am
Post new topic Reply to topic  [ 52 posts ]  Go to page Previous  1, 2
Post Posted: Fri May 20, 2011 5:21 am
tanshi wrote:
ok then i take it back! buy an LJ :)
yess!!
Vehicle: 06 jimny, 1.8 SE
Post Posted: Fri May 20, 2011 5:47 am
I just had a look and there is only about 30mm between the inside of the rim and the steering arm joint thingy . So I should only go about +10 max or it will hit.
5.5 inch rim + 1.5 inch = 7 inch so 19mm wider either side.
The offset is already +5 so I could probably go to +10. before it hits, depending on the thickness of the rim too.
Post Posted: Fri May 20, 2011 7:19 am
Hmm finding rims proving to be imposable. Maybe I should go for 16 inch instead of 15 's there are a couple around in 16 that would probably fit.
maybe I could put 6 stud vitara drums on ??
Post Posted: Fri May 20, 2011 8:36 pm
I'd go up to 16 if I didn't love my rims. Vitara are 5 stud. All Suzuki rim stud patterns are the same until the new GV shape
Post Posted: Fri May 20, 2011 10:20 pm
The GV ones must be the ones I was looking at .
So I if go to 16 inch what tire size would i be looking for?
I was originaly going for 235X 75. 15"
so I'd be looking for 215 X 75 r16 is that right?
Are there any good muddies in that size ?
Post Posted: Sat May 21, 2011 5:15 am
I have no idea what equates to what in the 16" world
Post Posted: Thu May 26, 2011 1:28 pm
this link helped me heaps...http://www.1010tires.com/TireSizeCalcul ... tter...was the torque loss with the 235's really noticeable?...considering 235's ILO 215's but don't want to lug the engine too much.
Post Posted: Thu May 26, 2011 9:21 pm
this link helped me heaps...http://www.1010tires.com/TireSizeCalcul ... kenutter...was the torque loss with the 235's really noticeable?...considering 235's ILO 215's but don't want to lug the engine too much.
I'd say yes. You'll never make it up a hill in 5th again and often you'll be down to 3rd. It's still quite drivable but the loss of driving enjoyment is definite. Steep hill starts will mean slipping the clutch. Offroad you'll lose engine braking on the descents and you'll need more momentum uphill.
Post Posted: Thu May 26, 2011 11:04 pm
So +25 wont work? I have 16x7 in a +25 i'll be selling soon. I'm going to GV rims.
Post Posted: Thu May 26, 2011 11:16 pm
If standard is +5 and 1.5" narrower, I don't thinj a 7" wide +25 rim would even come close to fitting.
I'd be aiming for +10 MAX, preferably closer to +5.
Post Posted: Thu May 26, 2011 11:28 pm
Yeah GV rims would be sweet I reckon.
Post Posted: Fri May 27, 2011 12:06 am
How much do you have to spend?
Lots of 16" rims in Japan for Jimny's - their very nice!!
Post Posted: Fri May 27, 2011 12:13 am
The only ones I found were 5.5" wide, something to keep in mind if you want to run larger tyres.
Some nice rims tho 8)
Post Posted: Fri May 27, 2011 12:21 am
How much larger do you want on a jimny? my 7.00x16 Creepies are approx 31" diameter and 8" wide when mounted on a 5.5" rim.
Post Posted: Fri May 27, 2011 12:22 am
And they have a TERRIBLE offset! I have a set under the house! You'd need 2" wheel spacers to run them! (soon to be trailer wheels :wink: )
Post Posted: Fri May 27, 2011 12:31 am
That's fine for 7.00x16s but they aren't the most common tyre. Most people who mod jimnys are going 235/75R15 or 30x9.5. 235s for example are supposed to be run on a 6" rim.
Post Posted: Fri May 27, 2011 1:14 am
from some pics that i saw on the jap jimnys they ussually run a 245/75/16 tyre (if im not wrong) that it bassically means is a 30" tyre..... the question would be is its eassy to find that size or not
really?? :? I do know they jimnys there are NT, and they sell two types of wheels, one to keep it standard, and other that have mroe offset to make a wider track.... dnt remmeber the website so dnt really know the correct offset.... i do like the look however.... i just dnt like the 5.5 wide... think is too thin... or wht is the really advantage to run a 5.5 rim over a 7" in offroad?
Post Posted: Fri May 27, 2011 1:17 am
I know, TERRIBLE offset :wink: :wink:
Post Posted: Fri May 27, 2011 1:23 am
found it!
http://origin-labo.jp/pc/jimny/wheel_dna02.html
they have or either +20 or -20 offsets
Post Posted: Fri May 27, 2011 1:32 am
that rim & tyre combo give me wood. 8) A+
Post Posted: Fri May 27, 2011 2:31 am
X2!!!! Very nice rims. 8)
Post Posted: Fri May 27, 2011 2:35 am
and if some one would tell us where he picked his wheels and tires up from, we could all have some creepies! :D
Users browsing this forum: Google [Bot] and 40 guests
