It is currently Sat Nov 07, 2026 10:50 am
Post Posted: Fri Jun 17, 2011 11:34 am
Please help I fitted a snorkel that I was running on my old Sierra to my new coily same style set up anyway it's not letting the engine suck in enough air what could I do to get more air
Sj80,31 claws, lift, winch, 6.5
Post Posted: Fri Jun 17, 2011 11:41 am
where is it being restricted?
Post Posted: Fri Jun 17, 2011 11:50 am
It seems to be where the snorkel goes into the air box there is none of that vacuum shit there I blocked it all off
Post Posted: Fri Jun 17, 2011 11:53 am
Pics?
Post Posted: Fri Jun 17, 2011 11:59 am
Photobucket won't work on my phone , would the air pipe from the hat going to the air box be affected if the bow or curve in the pipe sat higher than the carby hat ?
Post Posted: Fri Jun 17, 2011 12:05 pm
Not at all. With my body lift I had to modify the hat so it was almost a 180 degree bend from carby hat to air box.
Post Posted: Fri Jun 17, 2011 12:09 pm
I have flexy piping from the hat to the box frOm the hat so it doesn't matter if that's higher in any spots
Post Posted: Fri Jun 17, 2011 12:17 pm
Nope.
Post Posted: Fri Jun 17, 2011 10:58 pm
What makes you think that it is sucking enough air?
Are you having problems with how the car runs? Like revs dieing down.. Car not starting??
Post Posted: Sat Jun 18, 2011 12:42 am
Can you take a pic please????
helloo
Post Posted: Sat Jun 18, 2011 12:44 am
have you check to see if anything was blocking the snorkel or if there are any kinks in the flexy hose.
as lockie said... pics.
Post Posted: Sat Jun 18, 2011 1:07 am
Put a peice of paper in front of the head. If it sucks to it then its fine.
helloo
Post Posted: Sat Jun 18, 2011 8:27 am
like this?
:lol:
Post Posted: Sat Jun 18, 2011 9:11 am
Haha sorry guy I think I found the problem it's my carby being gay the jets keep blocking i used the back fire trick it worked for a bit I Also used carby cleaner which worked well what else works ?
Post Posted: Sat Jun 18, 2011 12:35 pm
carby shops work well with that problem.
Post Posted: Sun Jun 19, 2011 7:47 am
This cold weather and high speeds can freeze the carby jets.
I had to run my Sierra with snorkle turned off,
thus sucking warm air from under bonnet,
when weather was this cold.
Stopping for a minute,
heat from donk would rise and melt blockage,
then off I went.
Users browsing this forum: Google [Bot], jono165 and 72 guests
