It is currently Sat Nov 07, 2026 5:49 am
Vehicle: 98 Maruti
Post Posted: Thu May 19, 2011 1:56 pm
it sounds like a silly question but what is the best way to improve the standard suspention setup in a sierra but by keeping std leaves? i am not looking to replace it all just yet and would like to keep the suspention at around std high for now (will maby have a body lift installed to give tires room to brethe) any suggestions?
Post Posted: Thu May 19, 2011 2:09 pm
i looked into getting my springs reset and replacing with standard shockies. was gona cost abouut 50% more than what a full new arb OME kit was gona cost (both including shockies) plus they have a tendancy to sag much quicker.
arb kit only has a 2inch lift withc will disapear with a front and rear bar prety quick if ur worried about hight.
THINKING BEFORE POSTING!!!
Vehicle: Jeep
Post Posted: Thu May 19, 2011 5:45 pm
It depends on what load rating the springs are, a fair few get comfort springs as that gives the most flex, but they will sag/drop with any significant extra load... a Medium load spring may be the best option if you have any bars put on, or a toolbox and stuff in the back... :wink:
Post Posted: Thu May 19, 2011 11:07 pm
Exactly what are you wanting to achieve? You say you don't want any extra height, are you after more wheel travel, better load carrying, nicer ride etc.?
Post Posted: Fri May 20, 2011 3:50 am
Std leafs ride pretty well IMO. Only thing you can really do to improve on is get some descent shocks under it. Koni, OME etc
Lil Foot!
Vehicle: 98 Maruti
Post Posted: Fri May 20, 2011 3:54 am
basically i am asking for a slightly imposible task
i am looking to run 31 all terrains with a 2" body with a bit of hammering (maby moving diff forwards a touch) but that leaves me with the std suspention. now for legal reasons im looking to stay at 2" of lift (without tires) or just over that.
so i am looking to improve ride, if possible flex and a load carrying (for camping when loading the back with crap) of the std springs
from what i have being reading and from what sssierra has sugested a ome kit is good ride, pretty good flex and when sagged should roughly be 1.5" of lift, but with a 2" body that is giving me roughly 3.5" (give or take a bit) of lift
http://auszookers.com/index.php?name=Fo ... ic&t=21542 my other thread talking about 2" spring or body
Post Posted: Fri May 20, 2011 8:24 am
Not running springs for legal reasons but running 31... 31s aren't really legal either
Vehicle: 98 Maruti
Post Posted: Fri May 20, 2011 1:47 pm
a 2inch lift with 31 sticks out alot less then spring and body
Post Posted: Fri May 20, 2011 1:52 pm
i dont reckon... unless you do a guard chop as well.
when a sierra has 31s and no gap in the wheel arch the tyres look way larger than if theres a gap to be seen... its just an optical illusion but it happens.
realistically, you're going a 31" tyre which is illegal anyway, so might as well go the whole hog.
personally though i'd do a 2" spring lift and a good guard chop and fit 31's rather than add a bodylift.
Post Posted: Sat May 21, 2011 12:08 am
Your location says NT? If that's the case why are you worried about legalities :lol:
Post Posted: Sat May 21, 2011 1:02 am
I not sure if the law has changed, but NT used to be modifiers dream. Your man years ago was a modifier, and so, made laws that made modifying a very easy task, the best in OZ.
Too log ago, cannot remember his name, will come to me but.
Check your laws, may be very pleasantly surprised.
Vehicle: 96 x-90 & 92 vitara swb
Post Posted: Wed Jul 27, 2011 10:12 pm
Marshall Peron is his name i think ,, hotrodder bloke
Post Posted: Thu Jul 28, 2011 11:38 am
Thats him, most excellent statesman.
He was a modifier, and made it so all modifiers could have fun.
Post Posted: Thu Jul 28, 2011 11:53 am
fit some 2" extended shackles to gain another inch to go with the bodylift, that should have you fit 31's with some hammering. With only a bodylift 31's will rub like hell offroad
Users browsing this forum: Google [Bot] and 43 guests
