It is currently Fri Nov 13, 2026 6:13 am
Post Posted: Fri Aug 05, 2011 2:10 pm
im in need of a thermo fan to run in my sierra. just wondering for those who run thermo fans, which is a reliable or good brand to buy.
i dont want no supershit or repco brands.
i herd spal is a good brand, but pretty pricey
is there any others?
cheers
Post Posted: Fri Aug 05, 2011 7:51 pm
Depends on how much you want to spend. I have a 14 inch fan in a Vit. It is a cheap out of china job $60.00 but not from Supa crap or Repco. it works fine. I am using the Davies Craig sensor and adjustastable auto switch. Repco quoted around $250 for a 16 inch fan, and it looks like it came out of the same factory.
Davies craig fans are around $250 or so also. The important thing with these fans is the amount of air they shift (cubic metres per min etc.)
I have also wired mine with an isolating switch so as to be able to switch off when in deep mud water etc. to stop pulling shit into the radiator. this was the main reason for the fan swap. I have a large red light to tell me if the fan is off as a reminder.
Post Posted: Fri Aug 05, 2011 9:41 pm
I'll pay no more then $250 I guess
Yes I'll have it on a controller and a Overide switch as well
Was just after reliable brands thats all
So either spal or Davies Craig
Post Posted: Fri Aug 05, 2011 10:35 pm
try to get yourself a set of dual fans from a late model falcon from a wreckers and use one of them they afre bloody brilliant we use one on a drag car with a thermo switch that we scabbed from a magna and plumbed it int the top of the thermostat housing.
growing old is nature, growing up is choice.
Post Posted: Fri Aug 05, 2011 10:56 pm
There very good, but quick loud. My mate runs them in all his speedway cars
Are they the right size for a 1.3 radiator though.
Don't really want the fins hanging over the sides.
Want then more inside so I can make a surround.
Post Posted: Fri Aug 05, 2011 10:59 pm
I have a Hyundai Lantra A/C fan on my car. It never gets hot even sitting idling and I run a 1.8 turbo CA18det with an old 323 radiator (no bigger than vitara radiator) This is also with a big front mount intercooler sitting infront of radiator.
Apparantly has the same fan motor as the commodore units. It was $40 from wreckers.
Post Posted: Sat Aug 06, 2011 12:13 pm
+1
I have a single fan and part of the shroud from an AU Falcon in mine and it works well. Required a bit of a cut and shut to the shroud tho. I'm currantly switching mine with a Davis Craig adjustable switch but not that happy with the settup and would rather a switch like you sugest.
Post Posted: Mon Aug 08, 2011 4:11 am
Cheers For the help guys
Vehicle: Yellow Ute
Post Posted: Mon Aug 08, 2011 11:06 am
So you fellas are just running the thermo? Or both the thermo and engine fan?
Post Posted: Mon Aug 08, 2011 11:07 am
SPAL if there is no budget (14" is about $250-$300) or any OEM fan that will fit will usually work well.
Thermofan only for me. No room or need for engine fan.
Vehicle: Yellow Ute
Post Posted: Mon Aug 08, 2011 11:11 am
Yeah I have no room for an engine fan but on the beach the other day it kept overheating unless I could keep it around 30k's so I think the fan is to small? Though I think the biggest I can get on the current radiator is about a 12 inch.
Reckon that will be enough?
Post Posted: Mon Aug 08, 2011 11:16 am
At a guess that's stockton beach you're talking about?
That was seriously boggy out there by high tide. I went in at lavis lane end and was greeted by a Navara bogged to its axels in the middle of the track!
I was down to first for most of it on the beach... Back to the thread, with the standard engine fan I had no temp problems :)
Post Posted: Mon Aug 08, 2011 11:17 am
If you buy a quality fan that moves enough air, and your cooling system is correctly sized and maintained,then you should not have an issue.
Obviously the fan's size is limited by the radiator. Make sure your thermo is shrouded, and use a good quality thermofan controller.
Vehicle: Yellow Ute
Post Posted: Mon Aug 08, 2011 11:19 am
Cheers big fella!
Post Posted: Mon Aug 08, 2011 11:20 am
Not daves Craig :D mine shit itself pretty quick.
Vehicle: Yellow Ute
Post Posted: Mon Aug 08, 2011 11:26 am
That is the brand I was looking at :roll:
What is OEM?
Post Posted: Mon Aug 08, 2011 11:30 am
soon will find out if mine does :D
i bit the bullet and just bought a cheapie thermo fan,
didnt have the money to get a spal that i wanted
Post Posted: Mon Aug 08, 2011 12:08 pm
X2. Not what they used to be :?
Post Posted: Mon Aug 08, 2011 12:10 pm
What is OEM?
Original Equipment Manufacturer.
So its a factory fitted part. Ford fan, holden fan, Hyundai fan etc.... :wink:
Vehicle: Yellow Ute
Post Posted: Tue Aug 09, 2011 1:56 am
Maybe someone will be looking for one oneday.
Spal fans better prices then have been mentioned above prices and excellent service!
http://www.datsport.com/spal-fans.html
Users browsing this forum: Google [Bot] and 126 guests
